Buy a cobra texad block and go from there. Stage 2 heads and cams. P51 intake and call it good
You're looking at way more than 4k... texid blocks sell for more than a used 2v longblock. You need valves springs retainers, head gaskets, tune etc etc.
For $4K I would get a piston and rod kit. With rings and bearings it should cost around $900-$1000. Then you have to get the assembly balanced $200. Plus boring and honing (if your gonna bore it which i would)will cost $150-$200. Then I would get the heads cleaned up and better springs installed $300-$400. Then put together a blower set up for $1500-$1800. That will leave you with $400-$600 for odds and ends like gaskets and fluids.
That's pretty much where i'm leaning. I was looking into a forged bottom end and a set of really aggressive cams, but I don't think I'm going to get the power returns that I want if I would be staying N/A. It's helping I'm doing all the labor, the only labor I'm really paying for is the tune in the end. Where do you recommend I find a piston and rod kit for that amount, eBay? All the total costs for piston/rod combos from the places I've looked (like lethal performance) come out to around $1200, and that's without rings or bearings.
If your looking to make big numbers then you will be paying $1200 for rods, pistons, rings and bearings. You can find them at that price from propower performance parts. They have an ebay store.
He has a Mach 1, so your post is far from being revelant.
And? It doesnt mean he cant change his setup. You can pull a texad block fron junkyard for cheap. But easy powe I would honestly throw a vortech and call it good.
I'm gunning for around 500whp, basically. I'm trying to avoid having to spend another big chunk of money by buying a whole Cobra fuel system. Will the $900-1000 setups take that safely? Sorry for all the questions, i'm just making dead sure what build i'm going with before I start dropping thousands. Been down that road, and changing plans is never cheap.
