quick help guys
Oct 18, 2008 | 12:00 PM
quick help guys
will a 99 and up timing cover work with a 98 cobra oil pan?
Oct 18, 2008 | 12:27 PM
Quote:
Originally Posted by
Jasperstang308
Yes sir.
Oct 18, 2008 | 12:48 PM
will the accessories bolt up correctly? basically all i need to know is will it work correctly for the crank pulley and alt
Oct 18, 2008 | 12:50 PM
Jasperstang308
You need to explain what you are trying to do first.
2V, 4V? year?
Oct 18, 2008 | 01:04 PM
Oct 18, 2008 | 01:28 PM
Jasperstang308
4v in a 87 notch
Crank and alt will be fine.
In fact the alt bolts to the block so the cover doesn't matter.
Oct 18, 2008 | 04:40 PM
thankyou sir i found a good deal for a timing cover and oil pan and want to ****** it before its gone
Oct 19, 2008 | 12:55 PM
do you need the timing cover from a c headed motor for c heads or can you use one from a different year?
Oct 19, 2008 | 01:34 PM
Jasperstang308
I don't think it matters at all, other than what accessories and belt tensioner you want to run.
Oct 19, 2008 | 01:39 PM
hey while your on. are 01 cobra headers the same as 03 cobra headers?
