Mods!
Old Nov 10, 2008 | 08:30 AM
agarr19's Avatar
agarr19
Default Mods!
hey guys i got about 300$ to spend on mods i already have a K&N CAI and a magnaflow catback and now im looking for some power what should i do!
Old Nov 10, 2008 | 08:39 AM
steve0914's Avatar
steve0914
midpipe, or get a little more and buy gears
Old Nov 10, 2008 | 08:48 AM
agarr19's Avatar
agarr19
how much are gears?
Old Nov 10, 2008 | 08:51 AM
steve0914's Avatar
steve0914
gears are only 200ish, but install is the key call around to local shops
Old Nov 10, 2008 | 08:52 AM
avlon06's Avatar
avlon06
maybe handheld tuner, gears but its gonna cost more than 300 or T/B and plenum
Old Nov 10, 2008 | 11:01 AM
02 Ninja's Avatar
02 Ninja
You can buy the gears and then that will give you the incentive to save up for the install.
Gears alone run about $150 but you will need more than just gears to do the install so here http://www.latemodelrestoration.com/...0%201&comp=LRS check them out.
Old Nov 10, 2008 | 11:07 AM
avlon06's Avatar
avlon06
gears are pretty expensive once you get them and have them installed, however my clutch blew out so i had them both replaced at the same time and came out to around $700 or 1k (one of those numb)
Old Nov 10, 2008 | 04:48 PM
teej281's Avatar
teej281
4.6L Section Moderator
Gears and dont look back. but if you are dead set against getting gears, get an o/r x pipe. that will give you loudness and power. but i say gears overall. you are looking at a roundabout price of $400-$500 for total of the gears and the install. and if you do gears, get the master bearing and rebuild kit through american muscle so your rear is fresh for the new gears.
Old Nov 10, 2008 | 06:11 PM
boduke0220's Avatar
boduke0220
you could buy the gears and wait to get them installed
you could get a Throttle Body & plenum from pro products
you could get Steeda Underdrive pulleys and some appearance mod
you could get a Tri-ax and maybe a Throttle body too if you know the discount code to AM
A mid pipe and maybe A throttle body or Shifter
Old Nov 10, 2008 | 06:45 PM
tws1098's Avatar
tws1098
i say gears or something exhaust related.
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
firecoyote
Sep 27, 2015 02:37 PM
