Which would you go with?
Old Nov 19, 2008 | 08:28 PM
teej281's Avatar
teej281
4.6L Section Moderator
well it would be better than the stock ones wouldnt it??? i want low but i will keep the stock springs to change out when i go to the track. but just the better weight transfer on the street and the low look that i want. so thats why i put them in there. and my friend launches pretty darn well with sportlines in there so i dont see why i would do any worse.
Old Nov 19, 2008 | 08:35 PM
hpwrestler220's Avatar
hpwrestler220
im going to be different and vote suspension.. i love being able to take turns without going all over the place.. i stay planted
Old Nov 19, 2008 | 08:37 PM
SilvrStang's Avatar
SilvrStang
H&Rs are too soft for the drag setup you advised him with lol. Id go MGW and 4.10s. Performance> LOOKS
Old Nov 19, 2008 | 09:08 PM
E714FEVER's Avatar
E714FEVER
Originally Posted by 2000AZ5.0GT
you don't need tubular A arms to run a coilover kit, they work with the stock ones.
Yeah I know was just thinking about alittle weight reduction
Old Nov 19, 2008 | 09:52 PM
livefast1's Avatar
livefast1
i think the hr's would be too stiff, why not go with a set of 4 cyl. springs up front and cut your springs in the back. theres no way your gonna change the springs everytime you go to the track, its not hard but its not exactly fun either.
Old Nov 19, 2008 | 10:36 PM
2000AZ5.0GT's Avatar
2000AZ5.0GT
If that's the case, if he can do the work, a tubular K member would be the best option, It's only like 249.95 last time I checked, cheaper than gears and everything needed to install + a shifter, and it will reduce the weight on the front end quite a bit.
Old Nov 19, 2008 | 11:22 PM
amoosenamedhank's Avatar
amoosenamedhank
Lower springs aren't going to give you great weight transfer... you obviously don't get the point of LOWERING springs. Like the others have said, do the gears and the rebuild kit and cut the stock springs.
Oh and like someone else said, you're not going to change springs every time you go to the track. That's completely ridiculous, it's not like you're changing a set of tires here. I guarantee you try it once and never do it again.
Old Nov 19, 2008 | 11:50 PM
E714FEVER's Avatar
E714FEVER
Oh yeah the stock K member is heavy I was just thinkin about for now cause he can always choose to get a tubular k down the road and he would already have tubular a arms and coil overs to go with it. I just would hate to see him make the same mistake i did by buying lowering springs and installing them then 3 months later decideing to get a tubular front end package when I did my long tubes. I say do a arms and a nice coil over set up leave out the tubular k for when you decide its time for some long tubes.
Old Nov 20, 2008 | 12:09 AM
2000AZ5.0GT
that's probably a better idea man
Old Nov 20, 2008 | 11:53 AM
amoosenamedhank
I say cut the stock springs until you can afford to buy the whole front end package and do it all at once.
