1/4 mile time?
Old Nov 19, 2008 | 06:41 PM
stangman08's Avatar
stangman08
Default 1/4 mile time?
i have a 1998 mustang gt. im doing the full p.i swap to it and also adding bbk 1 5/8 long tuve headers and 4.10 gears with after market comp cams. im hoping it will be a hole lot faster than it is now. im going to take to a drag strip sometime but i was wondering what mile 1/4 miles time might be around. any suggestions? thax
Old Nov 19, 2008 | 06:48 PM
Soldier GT's Avatar
Soldier GT
I would say 13.6-13.8.
Old Nov 19, 2008 | 06:58 PM
foru2nv4's Avatar
foru2nv4
My 2003 mustang GT with saleen supercharger series IV, slp loudmouth catback exhaust, 2.91" pulley on supercharger, smaller pulley belt using a frabicated pulley that mounts on the water pump side of engine block to keep belt from slipping, pcm program by saleen, 75mm throttle body, 75mm maf air sensor programmed for 30lb injectors, 5 speed manual stick shift, 4.10 gears, I got this car to run 12.9374 in the 1/4 mile.
Old Nov 19, 2008 | 07:13 PM
BOSTANG's Avatar
BOSTANG
Am thinking about 13.7. 1/8 about 8.7. We all want more.
Old Nov 19, 2008 | 07:32 PM
hpwrestler220's Avatar
hpwrestler220
with aftermarket cams, saying you get a nice 60"..low 13's with some practice
Old Nov 19, 2008 | 07:39 PM
SilvrStang's Avatar
SilvrStang
Id say 13.6 at 99 mph
Old Nov 19, 2008 | 07:44 PM
teej281's Avatar
teej281
4.6L Section Moderator
well what kinda tires you gonna be running and anything done to the suspension??? i mean there are so many different factors that play into this. i mean if you're full bolt-ons with 4.10's and and sticky tires with some suspension done, you could easily be in low 13's...if you are a good driver. bad driver...high 13's.
Old Nov 19, 2008 | 08:10 PM
mustang_pa's Avatar
mustang_pa
ummm, ok and what was the original post?
I would say low 13's with a good launch, if that is all that is on the car now.
Old Nov 19, 2008 | 08:36 PM
teej281's Avatar
teej281
i mean there is a new edge which is a new car than yours with slicks and not much suspension with close to the same mods list as you will have run 12.1x's recently so i think that if you do suspension work and get some d/r's you will be running high 12's if you can drive.
Old Nov 19, 2008 | 09:25 PM
dimebag's Avatar
dimebag
you should break 12s, if im at low low 13s w. a stock pi motor and your talking cams and lts, it ought to be in the 12.7 range... but i say 13.1-13.5
and for the guy posting about his 12.9 run, id keep that to myself
