Impossible engine swap?
Old Nov 23, 2008 | 07:14 PM
2000GTponyexpress's Avatar
2000GTponyexpress
Default Impossible engine swap?
I replaced my 4.6 engine in my 2000gt (5 speed) with another 4.6 out of a 2001gt (Automatic). My old engine was 8 bolt crank, this one I got now is a 6 bolt crank, so I got a used 6 bolt flywheel which had been resurfaced. I put the 2001 engine in, fired it up and clutch would not release, I installed longer clutch fork pivot and adjustable cable & firewall adjuster & quadrant.My clutch still will not release and I just broke the pivot out of the T45 transmission. Has anyone had this problem?
Old Nov 23, 2008 | 07:20 PM
2000GTponyexpress
Default clutch pivot
the clutch pivot broke off the last time I pushed in the clutch to start it up after installing the transmission again after I adjusted the pivot length.The clutch fork evidently was against the pressure plate.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
mdj89
Sep 6, 2015 11:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
