horrible N20 leak
Old Nov 26, 2008 | 12:38 PM
sprayed99's Avatar
sprayed99
Default horrible N20 leak
i bougth this kit used and every since day one a month ago its had a leak around the n20 noid
it was already jb welded but still leaking so wtf do i do? i jb weld it more. and it still leaks but in a different place so i jb even more. etc. etc. etc
i have literally gone thourhg 4 packs of jb weld now. the noid can not be seperaterd from the line but the purge noid can. idfk what 2 do anymore. the bithc will not stop leaking.
i open the bottle and shut it instantly. take soappy water and put it on the area and see bubbles. i ****ing purge everything out and patch up that area. next ****ing day i do the same thing and while that area wont be leaking another will. its so ****ing frustating. any adivce?
im serisouly considering blowing the money i have in the bank for m/t et streets and buying antoher ****ing soleniod!
this is ****ing bull****!!!!!!
Old Nov 26, 2008 | 12:57 PM
sprayed99's Avatar
sprayed99
SOMEBODY HELP PLEASE!!!!!!!
Old Nov 26, 2008 | 01:09 PM
GTRACER88's Avatar
GTRACER88
Your noids that you have now are worthless... IMO i would just buy a new one... They are only like 60 dollars... http://www.dynotunenitrous.com/store...?idcategory=32
Old Nov 26, 2008 | 01:14 PM
sprayed99's Avatar
sprayed99
can i still use my nx purge and fuel if i just buy a dynotune n20?
Old Nov 26, 2008 | 01:25 PM
sprayed99's Avatar
sprayed99
in theroy its possible to stop the leak tho correct?
Old Nov 26, 2008 | 02:56 PM
dimebag's Avatar
dimebag
we need a few things, pics for one... that jeb weld job sounds..rigged
i just use a thread sealer on my **** and it works just fine.
you need to taket he line off the soleniod and clean everything up, inspect the threads on both parts and try again, with a differant sealer, jb weld isnt the **** to use., i had a leak i couldnt fix, it was messed up threads, just a thought.
check into it,and let us know
and...where do u live? i have a set of 275/40/17 m/ts...
buyuing a differant brand solenoid wont be an issue, just make sure it has the same fittings, and flows enough
Old Nov 26, 2008 | 03:05 PM
sprayed99's Avatar
sprayed99
well i bought it used and it already had jb weld on it. also i figured it was probably not threaded rite but i cant seperate the noid from the braided line cuz the jb weld
and pm sent bout tires...
Old Nov 26, 2008 | 06:49 PM
JayC's Avatar
JayC
If those are NX noids you can e-mail or call them for a return #. They will test and rebuild them at NO COST. All you pay is shipping. I send mine in every year for a freshening up.
Old Nov 26, 2008 | 07:24 PM
livefast1's Avatar
livefast1
haha yours probly dont have 4 packs of jb weld on em lol. i would just buy another one. with the amount of n20 you've probably already wasted it would have paid for itself ya know.
Old Nov 26, 2008 | 07:47 PM
JayC's Avatar
JayC
Well, you got a good point there...............
