First start after vortech install
Old Jan 8, 2009 | 11:06 AM
  #21
jvog's Avatar
jvog
well do u have a v1 or v2? The V2s are a lot quieter than the V1s. And I just started it with the new tune for stock maf and injectors, and the motor definately wasnt shaking like it was before..Do blowers make your rpms drop faster? Mine definately drop a hell of a lot faster than they did before. Also, dont exhaust shops have something they can put in your exhaust to check for leaks..and how much does it cost?
Old Jan 8, 2009 | 11:24 AM
  #22
H0SS302's Avatar
H0SS302
Just jack the car up and run your hand over all the connections.. you will feel an exhaust leak
Old Jan 8, 2009 | 11:28 AM
  #23
jvog's Avatar
jvog
I am also positive its at the manifold to h pipe connectiong
Old Jan 8, 2009 | 11:32 AM
  #24
jivepepper's Avatar
jivepepper
I have ran 42's and 60's on same maf it's calibrated in the tune.
Originally Posted by 2000AZ5.0GT
even though there is someone here running 500+rwhp on his Strim, I don't think you'll get to needing 60lbers with the S-trim
other than that, sounds fun man
I run 60's. I know tons of people on other sites running 500+ on a s-trim. The only reason I didn't break 600 was I was running out of fuel. So we didn't add anymore timing. But after 550 I think it's better use a T-trim. But **** I already have this and I'm poor.
Old Jan 8, 2009 | 06:58 PM
  #25
meansteedagt2004's Avatar
meansteedagt2004
Thats sweet!! Post some pics
Old Jan 8, 2009 | 09:34 PM
  #26
jvog's Avatar
jvog
So you are saying hes wrong and that I do need to put the bigger maf and injectors in the tune?
Old Jan 8, 2009 | 09:38 PM
  #27
H0SS302's Avatar
H0SS302
Trust what ox is saying about the sniper. It makes since to.. if the maf is calibrated it is already set up IN THE MAF for those injectors.. so adding it in the tune is throwing it WAY off.
Old Jan 8, 2009 | 09:41 PM
  #28
jvog's Avatar
jvog
i know it makes sense. the maf is calibrated for my 60s, so as air goes through the maf tells my ecu that i have 60 lb injectors and gives it fuel accordingly
Old Jan 8, 2009 | 09:43 PM
  #29
vanquish's Avatar
vanquish
Originally Posted by mustangman281
The maf already adjusts for the bigger injectors which is why you pick stock for both. If you had a pro m claibrated for 30lbs injectors but are running 60s then you tell sniper exactly what you have.
Using this example, ANYTHING besides 30LB. injectors you say exactly what you have?
  #30
H0SS302's Avatar
H0SS302
exactly thats exactly why you needed to put the stock settings back in the sniper tune
