24lb injectors
Old Jan 12, 2009 | 02:54 PM
stangalator's Avatar
stangalator
Default 24lb injectors
A friend of mine is selling hes injectors and mass air for a bigger ones, i was wondering if my fuel pump would be able to keep up with 24 lb injectors and a 80mm mass air rated for them? Would there be any other problem with the switch??
Old Jan 12, 2009 | 02:55 PM
hpwrestler220's Avatar
hpwrestler220
i dont think so. im 99% sure your fuel pump can handle quite a bit.. why do you need bigger injectors?
Old Jan 12, 2009 | 04:05 PM
stangalator
it goes along with the ported pi heads hes selling, its a package deal, so i was just going to install them any ways. Should I not install them?
Old Jan 12, 2009 | 04:10 PM
teej281's Avatar
teej281
4.6L Section Moderator
well he may be planning on a future of a little bit more power down the road. and it might just be one of those "deals too good to pass up". thats why im getting the o/r x pipe for my car. too good a deal to pass up.
Old Jan 21, 2009 | 02:20 PM
stangalator
bring back an old thread, ok, i got the injectors, i got both his stock ones and the after market ones and my orignals, so i have 19,22.5 and 24 lb ones which should i use?
hes the kicker, some of the 24 pound ones dont have caps on the ends, he told me that it doesn;'t make a difference because they are bolted down and the o-ring seals it, thats how he was using it, hes a picture of what im talking about...
it looks like the caps make the spray go more forward into the cylinders...
can i just buy caps for them somewhere?
Old Jan 21, 2009 | 02:55 PM
stangalator
OK i found the Fuel Injector Pintle Caps on ebay, not a bad price, they dont look necessary for sealing, but they do look necessary for correct spraying pattern.
Old Jan 21, 2009 | 06:34 PM
98redstang's Avatar
98redstang
i have the 24 pound injectors on a stock fuel pump so you should be good.
Old Jan 21, 2009 | 06:40 PM
livefast1's Avatar
livefast1
um don't wanna be a smart *** but can't you just pop them off the other injectors you have lying there.............
Old Jan 21, 2009 | 08:09 PM
98redstang's Avatar
98redstang
i was gonna say that lol... than i wasnt sure if you could so i didnt wanna look like an a$$ haha
Old Jan 21, 2009 | 08:36 PM
stangalator
i cant get the old ones off, plus they look different, like the 24 ones have a more rounded inside area, and the 22.5 ones have a square port
