Longtube Problems, need help
Old Feb 4, 2009 | 08:39 AM
CaptianMorgan65's Avatar
CaptianMorgan65
Default Longtube Problems, need help
there may be an install for this somewhere but i have been unable to find it, I am replacing my motor and I bought a set of SLP Longtubes, the passenger side went in easy, but I cannot get the driver side to set in, does anyone know if the steering shaft will go thru the headers or is there enough room for it to slide past, my headers are gapped as if to allow for the steering shaft. It feels like I can almost get it but i either hit the body or the brake master cylinder, any advice would be very helpful. I am putting my motor in from the top, not by dropping the k member so it changes things a little.
Old Feb 4, 2009 | 08:51 AM
jvog's Avatar
jvog
I think its supposed to go through them
Old Feb 4, 2009 | 09:16 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Pretty sure the steering shaft has to go thru bud
Atleast thats how most LTs work.. Good luck with the rest of the install, motor swapping isnt the funnest thing in the world
Old Feb 4, 2009 | 10:08 AM
CaptianMorgan65
hey thanks guys i was hoping it didn't but, at least i know now, yeah the motor swap isn't that bad other than having to do it in the driveway cause i'm broke, id rather swap the motor than change the heater core like i did last weekend. anybody got any tricks for clearing the body to blot up the header?
Old Feb 4, 2009 | 10:17 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Did you take the shaft out? I kno when I pulled my motor I took the shaft off the rack and set it aside. I also had my hood off.
Old Feb 4, 2009 | 10:50 AM
CaptianMorgan65
yeah i got my hood off and i pulled the motor out trannie and all, i went to take the steering shaft loose but it has a stop on it and it won't let me slide it off, does the whole shaft come loose from the fire wall? i have the motor 3/4 of the way back in, but my problem is the header needs to be pushed up about an inch and im hitting the floor pan, but if i drop the motor into the bay more then the header gets hung up on the brake master cylinder and i can't manuver it on.
Old Feb 4, 2009 | 11:24 AM
BOSTANG's Avatar
BOSTANG
The shaft is going to have to come off.
Old Feb 4, 2009 | 11:48 AM
CaptianMorgan65
i took the shaft loose on the axle side, now it swings free, does the whole rack come loose from the fire wall?
Old Feb 4, 2009 | 01:57 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
I'm a little confused as to why you are getting caught up on the firewall. Could you get some pictures or something. When I did my motor swaps, I always take the trans out first, it makes ploppin that motor in the SO much easier
Old Feb 4, 2009 | 02:13 PM
CaptianMorgan65
not really getting hung up on the fire wall, it's more like the floor pan on the bottom, i have the motor raised up so i can get the pipe up to the block, the front part of the header lines up fine, the back (firewall side) needs to be pushed up an inch to line up with the holes, but when i push it up it hits the floor pan and i cannot go any further, i know the motor needs to be dropped in more to clear this, but when i lower the motor down the brake master cylinder prevents me from sliding the header in, i am at work all day but i plan on working on it a soon as i get home, but if i can't get it i'll try to post some pics.
