HID Question
Old Feb 5, 2009 | 03:58 PM
Aereon's Avatar
Aereon
Originally Posted by ARdoller
if you want HID's, get projectors. the light output SUCKS when using HID's in headlights made for halogen bulbs. dont let anyone tell you otherwise.
Aftermarket projectors are garbage, I bought a set to compare with the projector retrofit and the light output is garbage.
Projector retrofits are the only way to go if you want a bright setup.
Old Feb 5, 2009 | 08:06 PM
alexr's Avatar
alexr
Projector retrofits are the only way to go if you want a HID setup.
fixed.
not only is the light output of HID's far greater in projectors, theyre also the only LEGAL way to run HID's.
when comparing HID's in halogen (stock/smoked/clear) housings to HID's in a projector eye, its a lot like how an adjustable flashlight works. when you turn the head of the flashlight so the beam is condensed together, as one solid beam, that is how halogen lightbulbs look in halogen housings. when you turn the head of the flashlight so that the light is more broad, this is how HID's emittance in halogen housings look. the light will be more of a white color, but you will notice a much greater area of view, at a much LESSER intensity. and when you turn the head of the flashlight back to its original high intensity beam, picture it white at a much greater brightness, and that is what HID's should look like when used in a projector.
catch my drift?
Old Feb 5, 2009 | 08:08 PM
alexr's Avatar
alexr
so far, the best light output for our cars, is a 4300k or 6000k HID kit, and a retrofit of Acura TSX projectors in smoked/clear aftermarket housings.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
