Tfs intake progress pics!
2010 Blue Ball Award Recipient
So it was just because of the low mileage that everything looked so nice. Gotcha, cause I know I had a lot of carbon/gunk built up throughout my intake, and the ports on the heads were relatively dirty.
What exactly is a pvc system? I am under the impression that it has something to do with emissions, but I really don't know what/how/or why.
Update:
Well I'm at a stand still because TFS forgot one little clip. It's called a hose barb clip and is used when replacing the steel coolant line under the intake so it can be replaced with a rubber hose. It helps keep the hose from coming off or leaking, and replaces the rubber O rings. I think I could get by without it but I'm just going wait and do it right.
Well the Accufab Special 96-98 single blade oval throttle body showed up, and so did the stock cobra tb I was going to use. I also received the little clip that TFS forgot. As soon as it warms back up I will gwt back at it.
Some more pics lol.
This should let some air in.
Bling bling. (I usually not into shinny stuff lol.)
Some more pics lol.
I'm fine with it besides I want it to 4 " until about foot before the Intercooler outlet. So maf faunction will be correct. I might paint it black. Another guy just cut his oil fill tube down and apoxyed the top back of the v cover on his bullit intake.
PCV - Positive crankcase ventilation
PVC - Polyvinyl chloride (the white plumbing pipes).
Just had to chime in with that.
