Squeaking...
Old Mar 16, 2009 | 11:03 AM
avenged_motorhead's Avatar
avenged_motorhead
Default Squeaking...
I know one or both of my quad shocks in the rear is bad, but more recently ive been hearing a squeaking from the front of the car also, i cant exactly pinpoint where from but i hear it mostly when im puttin around in first or second like when i give it some gas with then let of immediatly just a slight romp, i was thinking either its the struts, motor mounts or front sway bar bushings, just would like some input, thanks for your time.
Old Mar 16, 2009 | 05:03 PM
Obsequious1's Avatar
Obsequious1
My car had a squeeking noise in the front for the longest time. I noticed it the most while driving over speed bumps. After I removed my front sway bar, the squeeking went away. I'm not saying you should remove your sway bars. Most likely its you sway bar bushings. Shoot some white lithium grease in your bushings and see if it goes away. You could also remove the sway bar to make greasing it easier.
Old Mar 17, 2009 | 07:37 AM
avenged_motorhead
I will try that thanks.
94mustangandstuff
Oct 11, 2010 01:29 AM
grruminator78
Mar 13, 2007 01:57 PM
