gauges
Old Mar 22, 2009 | 01:19 PM
99 GT vert's Avatar
99 GT vert
Originally Posted by black35th
Can you explain that? It just doesn't make sense to me, because the O.D. is the exact same for a 245/45 and a 315/35. If the O.D. was different then it would be thrown off due to the tire making more/less revolutions. I just don't understand how the width would make a difference.
I'm not trying to pull a BS flag here, just wondering.
with a 315/35 the 35 means the side wall is 35% of the size of the 315 width
Old Mar 22, 2009 | 01:24 PM
black35th's Avatar
black35th
Yea I understand that, but the outside diameter measures the same as a 245/45. I still just don't understand how that would throw your speedo off by 6% with a tire that is wider, but not taller/shorter in any way.
Old Mar 22, 2009 | 02:36 PM
Y2KGT's Avatar
Y2KGT
i'll be sure to tell the police that next time i get pulled over for speeding
i still think that is not feesable....
where's the hardcore admins when you need'um?
Old Mar 22, 2009 | 03:01 PM
99 GT vert's Avatar
99 GT vert
my 275/35/18s measure the same as my old 275/40/17s so there is not a big difference unless you get one with a bigger side wall
Old Mar 22, 2009 | 08:13 PM
2000AZ5.0GT's Avatar
2000AZ5.0GT
not all 245/40's are going to have the same sidewall height as all of the 315's.
Some manufacturers just cut their tires wider.
FOR INSTANCE, BFgoodrich R1 tires for 315/35/17's are 25.5" tall, and are 816Rev's per mile
the same exact tire's, in 245/40/17's are 24.2" tall and have 860 revolutions per mile.
Make more sense?
BTW, here's the spec sheet that I took this info from
Old Mar 22, 2009 | 08:16 PM
2000AZ5.0GT
Oh, BTW, you can do that for every single tire listed, Goodyear Eagle F1's are 25.7" tall for 315's, but only 24.7" tall for 8" wheels
Old Mar 22, 2009 | 08:17 PM
945LSTANG's Avatar
945LSTANG
cobra gauges FTW...
Old Mar 22, 2009 | 08:37 PM
H0SS302's Avatar
H0SS302
Originally Posted by 945LSTANG
cobra gauges FTW...
yea ifffffffffff you can sping your block to 7k.. lol I waited n waited for an auto mach 1 cluster so i wouldnt have that issue.
Old Mar 22, 2009 | 08:57 PM
2000AZ5.0GT
considering he has a 2003 cobra, I would imagine that he can spin it that high
plus, it doesn't make much sense to have those if your not running a boosted car, the boost gauge will just sit there at 0psi forever
Old Mar 22, 2009 | 09:06 PM
H0SS302's Avatar
H0SS302
i have a solution for the boost gauge....turbonator!!!!!!!!
