Header fix ?'s
Old Mar 29, 2009 | 05:01 PM
03GTwhos's Avatar
03GTwhos
Default Header fix ?'s
I have been running a set of Hedman headers for awhile now and I am now taking them back off to fix this BIG exhaust leak I have had since installing them. I want to know what you guys think would fix this leak. It is the driverside header, it's a 2-piece design so the steering shaft can go through the primarys. It leaks bad where the two primarys slip together right before the collector. You can feel the exhaust pulsing on your hand when you put it next to the joint. I can't weld it cause the tubes are like 1/32" apart it's real tight. It kicks the check engine light on about everytime you drive it and sounds really bad under a load. Any help would be greatly appreciated.
Thanks Matt
4cylinderplus2
Oct 9, 2020 07:45 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Thunderball
15
Nov 22, 2015 11:49 PM
flash_xx
Oct 16, 2015 07:23 AM
junior04
Sep 28, 2015 10:53 AM
