What to spend $$ on???
Old Apr 8, 2009 | 01:04 PM
03GTwhos's Avatar
03GTwhos
Default What to spend $$ on???
I am going to have about 1K to spend on the car. Should I get LCA/UCAs, Subframe connectors, and torque box kits, what ever else to make car hook better. OR Get the CMS Stage 2 N/a Cams and springs and dyno tune it? What do you guys think?
Thanks Matt
Old Apr 8, 2009 | 01:10 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Do you have gears yet?
Old Apr 8, 2009 | 01:14 PM
03GTwhos's Avatar
03GTwhos
Yeah, 4.10's, just not installed yet.
Old Apr 8, 2009 | 01:42 PM
Sxynerd's Avatar
Sxynerd
31 spline aXles and install...
Old Apr 8, 2009 | 10:08 PM
03GTwhos's Avatar
03GTwhos
What can the factory axles handle as far as abuse?
Old Apr 8, 2009 | 10:15 PM
Sxynerd's Avatar
Sxynerd
Hook once at any level and you'll find out real quick, lol.
400ish but the better you hook the less it will last. soooooo, either buy cheap tires or a ram clutch.
Old Apr 8, 2009 | 11:54 PM
DVS_Z28's Avatar
DVS_Z28
+1 build up that rear first
Old Apr 9, 2009 | 06:55 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
With enough traction, you will/can destroy a rear-end with 100 HP. I say, forgo the HP route and go suspension mods for twisties
what?
Old Apr 9, 2009 | 08:47 AM
03GTwhos's Avatar
03GTwhos
So 31 spline axles, spec clutch, UCA/LCA's, Subframe connectors, and torque box kit. Do those parts sound like a sound investment??
Old Apr 9, 2009 | 09:16 AM
Jazzer The Cat
Retired Moderator
^ Full-length SFC's are ALWAYS a great investment on an SN95.
If looking at LCA's/UCA's, I recommend ones that have a spherical end on each to reduce the bind of your 4-link out back. Look into UPR for some great parts for this issue.
Jazzer
