Weight Distribution
Old Apr 20, 2009 | 05:27 PM
Matthew_B's Avatar
Matthew_B
yeah. I'll look into the manual steering rack, sounds like a good option. I also am going to be looking into getting spacers for said rack, to increase actual turn angle. (not too much or I'll have to roll my fenders..or maybe I'll roll em)
But that's if I decide to actual pursue trying to drift in this car as like..a sport instead of just a goof off thing.
TYVM for such fast responses
Old Apr 20, 2009 | 05:31 PM
2000AZ5.0GT's Avatar
2000AZ5.0GT
Don't worry about it man.
there is someone on these boars that is into drifting as well, so I'm sure he'll know more about it than I do, he could probably help you more than I am. Hopefully he comes in too
Old Apr 20, 2009 | 05:34 PM
Red2002GT's Avatar
Red2002GT
I hate the carbon fiber look but the factory GT hood weighs a ton.
Anyone know the weight of stock hood vs carbon?
Old Apr 20, 2009 | 05:36 PM
Matthew_B's Avatar
Matthew_B
Couldn't you just paint the CF? I'm pretty sure the carbon hoods are around 20-30 lbs or so? I'm guessing a stocker would be like 40-something? Or maybe I'm retarded.
Old Apr 23, 2009 | 08:19 PM
jmsjags's Avatar
jmsjags
i think the 99-00 hoods are about 10 lbs lighter than the 01 hoods too. can anyone verify this?
Old Apr 23, 2009 | 09:10 PM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
if you nix the power steering, you will no longer have power brakes... theres a manual brakes conversion kit that upr makes, you should look into it
http://www.latemodelrestoration.com/...0%201&comp=LRS
Old Apr 24, 2009 | 07:45 PM
Matthew_B's Avatar
Matthew_B
hmm. I'm starting to reconsider dropping the power steering/brakes then. Maybe I'll just go the old fashioned way and ADD weight (sound system/whatever) to the rear, and just add enough power to negate the effect. That way I can have the balance and not lose drivability. (Im planning for this to be my DD)
I wouldn't mind manual steering much, but I have no idea how much manual brakes would affect drivability.
Old Apr 24, 2009 | 11:00 PM
99BlackPonyGT
if you want to test it, take your car out on a backroad, get up to speed, put it in neutral and then shut the car off... no booster, so there wont be any vacuum held...you shut it off while driving and it will be the same feel as using manual brakes...its not that bad, ive had my car stall on me at 65 before and it stopped fine...go out and test it if you arent sure
Old Apr 24, 2009 | 11:05 PM
99BlackPonyGT
also.... theres a guy here who did a 408w swap, but he switched to foxbody stuff and mounted the booster under the hood or something...you could PM him... ZW99GT
Old Apr 24, 2009 | 11:31 PM
Matthew_B's Avatar
Matthew_B
alrighty, Ill test it tomorrow ty
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
jar_are_red
Sep 24, 2015 07:03 AM
Sep 8, 2015 11:50 AM
