acceleration problems
Old Apr 26, 2009 | 12:19 PM
bmmf's Avatar
bmmf
Default acceleration problems
Hi All,
I am a newbie to the forum and hopefully someone out there can help me before I take it to the dealership.
Car:
02 Ford Mustang GT
5 speed
The problem:
When I go to give the car some gas it just revs but no acceleration. Then I let up off the gas its fine and cruises like it should but everytime I go to give it gas it just revs. It only happens when I go to give it medium to a lot of power. The car struggles real bad driving up hills but its less noticeable on flat ground.
Things I've changed:
Fuel filter
Spark plugs and boots/wires
Thanks,
Phil
Old Apr 26, 2009 | 12:33 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
When you say "it just revs" do you mean the RPMs increase but the car does not accelerate? If so then it sounds as though the clutch is slipping, is there any free play in the pedal?
If you push on the clutch pedal with your hand there should be 1" to 1-1/2" of travel before you feel the throwout bearing pushing on the clutch spring. If the pedal is rock hard from the get-go then the cable is too tight...
Here's how to adjust the stock pedal.
If there is free play in the pedal then the clutch could be toast...
Old Apr 26, 2009 | 03:35 PM
JJ03MustangGT's Avatar
JJ03MustangGT
+1, kinda sounds like the clutch.
Old Apr 26, 2009 | 04:39 PM
mustangman281's Avatar
mustangman281
Banned
I'm gonna say the clutch also.
Old Apr 26, 2009 | 07:47 PM
bmmf's Avatar
bmmf
Just checked the car and there is no play with the clutch pedal. It is rock solid so I was thinking about adjusting it a little so it wouldn't be so tight. Would adjusting the clutch fix the problem or simply postpone it for a little while? Thanks for the help
Old Apr 26, 2009 | 08:06 PM
steve0914's Avatar
steve0914
maybe learn to drive a 5 speed?
Old Apr 26, 2009 | 08:08 PM
mustangman281
Banned
Your clutch is on the way out. If your still have a stock quadrent and cable then its self adjusting.
Old Apr 26, 2009 | 09:06 PM
bmmf's Avatar
bmmf
I really hope its not that.
Taking it to my buddy's shop tomorrow but I am pretty sure it is the clutch too. Starting to hear from slipping noises when I try to gas it.
Old Apr 27, 2009 | 03:54 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Read the link I posted above and adjust the clutch cable--the OEM setup is not "self-adjusting" as has been posted, but instead is a semi-automatic mechanism requiring that you lift the clutch pedal to release a pawl that allows the quadrant to reposition.
One issue might be that the previous owner bent the release pawl out of the way, as described in the Corral article--in thei case you'll have to manually release it as described in the link.
Once you get the cable adjusted properly there are three possible outcomes:
1. You caught the problem in time amd the clutch disc is somewhat prematurely worn but it and the pressure plate are OK nonetheless;
2. The clutch disc is shot, but the plate is OK (may need to be resurfaced);
3. The disc and plate are both toast (plate has surface cracks from overheating, and cannot be resurfaced);
Both 2 and 3 mean it's new clutch time--2 will cost a bit less than 3 to get repaired.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
zanemoseley
Sep 6, 2015 12:58 PM
