Next step?
Old Apr 30, 2009 | 11:50 PM
RyanK's Avatar
RyanK
Default Next step?
Now that I got my rear end all sorted out and on order, My next project is suspension and tires? Now for the tires I would like to go with drag radials, And on the suspension Im obviously going to use it to race. My budget is about 500-1000 for suspension and tires, Any help? thanks guys
Old May 1, 2009 | 12:30 AM
jmsjags's Avatar
jmsjags
for $1000 ur not gonna get much... tires themselves will be about $400
but i would definitely go with some subframe connectors
http://www.americanmuscle.com/maximu...onnectors.html
Old May 1, 2009 | 01:11 AM
RyanK's Avatar
RyanK
Well how much will it take?
Old May 1, 2009 | 01:24 AM
H0SS302's Avatar
H0SS302
you can get upper/lower control arms for around 200 bucks depending on where you look. FLSFC are about 100. 400~ for tires. 300 left for gears.
Old May 1, 2009 | 02:52 AM
jmsjags's Avatar
jmsjags
$300 for gears? he'll hafta get em installed too that's another $300 right there... and he'll most likely have to take the control arms and subframe connector to a shop to have installed also.
OP the sad truth is $1000 doesn't really get u very far with car mods. u can either go tires and gears for about $1000 if u want power, or u can go tires, subframe connectors, springs, and shocks/struts if u want suspension
Old May 1, 2009 | 03:39 AM
H0SS302's Avatar
H0SS302
Ya think? Having em all sitting in my room is a lot better than nothing. At least he will have everything there. He just has to get em installed.
Old May 1, 2009 | 07:50 AM
Mustang_NTriangle's Avatar
Mustang_NTriangle
uca's, lca's, subframe connectors
Old May 1, 2009 | 12:37 PM
ddmsgtr1's Avatar
ddmsgtr1
I plan on doing uca/lca's with a buddy of mine, but subframe connectors your going to need to take to a shop with an experienced welder, and if you plan on doing some good ca's, you might as well have them weld up your tq. boxes while they're at it.
Old May 1, 2009 | 01:53 PM
RyanK's Avatar
RyanK
And I already have gears If your talking about the gears for the rear end and I wont have to take any of them to get installed Because I will do it myslef, So should i do shocks and the other stuff or should i do tires?
Old May 1, 2009 | 02:00 PM
blee69mustang's Avatar
blee69mustang
~$400 tires
get for sure: springs/shocks/sub frame connectors
drag racing: lca/uca
or
road racing: sway bar/ CC
hopefully you can work on your own car to save on labor costs
