locked up engine
Old May 2, 2009 | 11:45 AM
thehulk07's Avatar
thehulk07
Default locked up engine
I have a air intake that goes under the fender, it was raining real bad a few days ago, and my engine locked up. The insurance adjuster is coming out to look at the car i have full coverage on it, but willl me having a modified air intake void the insurance or not?
thanks
Old May 2, 2009 | 11:47 AM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
thanks
ask your insurance company?
Old May 2, 2009 | 11:50 AM
black35th's Avatar
black35th
Uh, throw the stock intake back on it real quick.
Old May 2, 2009 | 11:56 AM
99BlackPonyGT
i would say this isnt good....my last insurance adjuster was a car guy and he knew what he was looking for when it came to my car.... nothing beats insurance fraud
Old May 2, 2009 | 12:19 PM
jvog's Avatar
jvog
Uh...did you drive into a pond? How did you manage to suck in that much water?
Old May 2, 2009 | 12:26 PM
mustangman281's Avatar
mustangman281
Banned
The only engine I have ever seen that locked up due to hydrolock was a dodge ram 5.7l hemi. He was off roading and wnet into a hole at 5000rpms and the water was over the hood. It threw the rod right thru the block.
Driving thru a puddle will not do this. The small amount of water will hit the maf causing the computer to dump fuel and stall the engine. From there the water evaporates and settles in the cylinder locking it up.
Pull all the sparkplus and let is sit in a dry place for a day. Then spray in some wd40 in all the sparkplug holes and slowly turn the motor back and forth. Once is starts to turn easier put all the plugs in and start the car.
Old May 2, 2009 | 12:28 PM
99BlackPonyGT
or let the adjuster write you a nice fat check, and then do this....then use insurance money to mod
Old May 2, 2009 | 12:43 PM
black35th's Avatar
black35th
Coming from the guy that just lectured me about insurance fraud.
Old May 2, 2009 | 12:58 PM
99BlackPonyGT
its not the same thing...if the adjuster comes and determines that the engine is locked up, then let them pay for it... engine stopped running, he parked car, insurance adjuster comes to see it...
thats diff than swapping out parts and pretending the car wasnt modified
Old May 2, 2009 | 01:50 PM
black35th's Avatar
black35th
LOL, either way, I think one of the definitions of insurance fraud is using insurance money for a different purpose than it was intended. If they wrote him a check for a new motor only to find out that his was fine, and then he spent the money on some "aftermarket performance parts" they would be pissed and there would probably be some court involved. Wouldn't you think?
