are they worth doing? how big of a change in the way it shifts also any improvement in quarter time? or just easy to make consistant or what? just trying to figure out what the deal with them is, anything you know please fill me in
The firewall adjuster allows you to pick where in the travel of your clutch pedal your engagement point will be. The new quadrant simply keeps the clutch engagement firm and consistent because it the stock plastic piece which is prone to flex with a heavier clutch, is replaced with an aluminum piece.
install is kinda a PITA bc u gotta get under the dash and sh*t.. IMO, i woulda been fine with teh stock quadrant/adjuster... i didnt notice a huge difference besides that i can adjust where it grabs
I have the UPR fire wall adjuster and Quad, I had them installed when the Spec Clutch and Alum Flywheel went in last summer. I love it. Shifts are on point! And the spot where your clutch engages stays where you want it. Its not a product designed for a higher performance, more to replace factory weakness.
