Question
Old May 20, 2009 | 01:39 AM
RyanK's Avatar
RyanK
Default Question
This is probably asked alot but how much horsepower can the stock 4.6 2v block handle? and how much boost?
Old May 20, 2009 | 08:20 AM
Mustang_NTriangle's Avatar
Mustang_NTriangle
Stock block meaning no forged internals under 400 rwhp but it is all in the tune. I would keep in under 380 rwhp and at 8 psi. I was at 10 PSI aftercooled 400 rwhp and blew engine after 3,000 miles.
Higher boost = higher compression along with consist high reving rpms is not good for stock pistons meaning do not beat on it.
I recommend you go with 8 psi but add either LTs or Blower Cams to reduce your psi/compression on stock internals but you willl have more power with less strain on your pistons.
Note: Stock cast crank is good for 600 rwhp.
Old May 20, 2009 | 10:03 AM
Roush2002's Avatar
Roush2002
nope you are the first to ask, lol just kiddin. Triangle has good info up top there. Its all in the tune from what I have been told. I only have two fears... my wife beating me if mine ever goes ka-pow and the bill so I dont beat on it much. If you cant pay dont play!
Old May 20, 2009 | 10:59 AM
Eagle2000GT's Avatar
Eagle2000GT
I checked your garage and there was nothing there. I don't remember if you have an automatic or manual transmission. The tuners I've talked to all say not to go higher than 370-380 rwhp on a daily driver (manual transmission). That's approximately 435-450 hp at the crank. An automatic has more parasitic loss so the same setup on an automatic will get you about 350-360 rwhp.
Putting on PI heads will increase your compression ratio so you should limit the boost to 8 psi (intercooled).
Old May 20, 2009 | 03:04 PM
RyanK's Avatar
RyanK
Yeh mine is a 98 gt with a 5 speed and its the t-5 tanny, cause the way things are going i was looking at mmr because im going to tear the engine down in the summer anyway and im planning on going vortech with this car after the pi swap idk i guess it will all come in time
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
