Engine build update!
Old Jun 3, 2009 | 03:36 PM
jvog's Avatar
jvog
Default Engine build update!
So, I got my shortblock back last week and took the mustang off the road on Monday. Since I don't have all the new parts yet I have been working on it a little bit at a time. As of right now the engine and trans are ready to be pulled, all I have to do is unbolt the trans and motor mounts. So far it hasn't been as hard I thought it would be. That is, except for that PITA power steering pump bolt. I heard a lot of people don't put the third bolt back in, any opinions on this? I meant to get some pics but my friends camera was in his car and his car was at the shop. I'll get some eventually.
Old Jun 3, 2009 | 03:40 PM
Tim99GT's Avatar
Tim99GT
Very nice! well i would also like to know about this power steering bolt. I pulled the whole top end off my car sunday and plan to pull the motor/trans soon to make way for the new setup.
sucks not being able to drive it
Old Jun 3, 2009 | 03:45 PM
jvog's Avatar
jvog
Hmm I thought I posted this general discussion, but I guess not so mods please move it.
Tim, have you read up about the power steering bolt problem? If not, it is a pretty big pain. Its behind a hard line. You can either take the line out and have refill the system with fluid, or use a wrench and back the bolt out a little bit at a time. If you do it that way, you have to take the other 3 bolts out first so you can move the pump away from the block, otherwise the PITA bolt will hit the hard line while you are taking it out. I'm not sure what people do when they don't use it...they must just cut it off becaues otherwise you'll have to take the line out anyway...
Old Jun 3, 2009 | 03:49 PM
Tim99GT's Avatar
Tim99GT
Hmmm, i will have to check into this. Post pics when you get a chance so we can all see.
Old Jun 3, 2009 | 03:58 PM
jvog's Avatar
jvog
The car is at my friends house so I won't be able to get pics until I go over there again. If you want a pic of the bolt, I doubt I will be able to get a good pic of it. Its pretty hidden
Old Jun 3, 2009 | 04:19 PM
Tim99GT's Avatar
Tim99GT
I guess i will see it when i get to that part of the swap
Old Jun 3, 2009 | 06:03 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
I have not driven my car since last August before I cracked my stock piston. It is killing me that my car is not done yet. From the looks for things it won't be done until end of July
Old Jun 3, 2009 | 06:29 PM
99 GT vert's Avatar
99 GT vert
gar i wish i has more money to do my build i just bought my rods and pistons and new injectors, going to pick a block up in a couple weeks, need to find a crank, then order some cams and i will be set to put the new one together
Old Jun 3, 2009 | 11:25 PM
jvog's Avatar
jvog
I've been doing some reading for the rest of the swap and can't seem to find an answer. If I am reusing stock heads/cams, do I need to remove the cams to get the head off or can I just leave the cams in the heads...
Old Jun 4, 2009 | 07:16 AM
CAMDUP's Avatar
CAMDUP
its been a while since i did it , but i think they can stay in the heads
