cams
Old Jun 24, 2009 | 10:34 PM
02redstang's Avatar
02redstang
Default cams
I'm replacing my timing chains and thanking about cams too so what is a good cam and duration to go with. I want a lopee idle and do i need to replace valve springs.
Old Jun 24, 2009 | 10:39 PM
teej281's Avatar
teej281
4.6L Section Moderator
definitly change valvesprings anytime you replace the cams just to be safe. And you might wanna look into Cushman Motorsports. Jim makes some pretty awesome cams and he can grind you some custom too.
Old Jun 24, 2009 | 11:18 PM
mrtstang's Avatar
mrtstang
It's never a bad idea to change the springs! While not really necessary on "some" smaller grinds, it's almost always recommended on larger ones. So it really depends on what profile you plan on running.
Is your car n/a? Will it see forced induction at some point? These factors are very important when selecting the proper specs. Also weather you decide to degree your cams (you really should) or not should also be taken into consideration.
If you don't want to run into possible ptv clearence issues (this is one of the drawbacks to the pi heads) i would go with a custom grind! There are too many off the shelf cams out there that are cutting it way to close!
Now if you don't mind notching your pistons, then you can run more agressive profiles, and not have to worry about ptv issues.
Obviously the more agreesive profiles will have a lumpier idle, but a good tuner can make a smaller cam idle like a bigger one, and vice versa...within reason of course!
Old Jun 25, 2009 | 10:36 PM
02redstang's Avatar
02redstang
I wood like to put a super charger on it but it wooden be for a yr or two. I need to replace the timing chains so thats y im thanking about doing cams too. Its a 02 Gt and the mods are cold air intake, 75mm throttle body, Plenum, SCT X3 tuner, off road 2.5 X-Pipe, American Thunder, 2.5 exhaust systems (flow masters). What about 234/238 Duration & .550/.550 Lift or 226/230 Duration & .550/.550 Lift buy (comp cams) $589.99 What the cost on custom grind cams
Old Jun 25, 2009 | 11:14 PM
teej281's Avatar
teej281
Custom grinds from CMS are the same price as off the shelf cams IIRC.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
