Too tall a tire?
I finally got some DRs for the track. I found a good deal on some 325/45/17 M&H racemasters that are mounted on some 17x9 Bullitts. I used these at the tack this past weekend along with some new rear control arms and was able to shave a tenth off my 60ft (1.98 to 1.88) and .12 off my ET (13.72 to 13.60) over using my Sumitomos with stock control arms.
With the mild bolt-ons in my sig, are these M&Hs too tall a tire for my car?
Get you some good shocks/struts to help weight transfer. If all you want is drag racing, then get some cheap lakewoods, or get Strange 10-way's if you want adjustability.
Oh and those 325 M&H's run narrow, they arent any wider than a 275 M/T.
I thought they might be a bit tall. They look great since they fill in the wheel well nicely! AND they are definitely on the narrow side (they are narrower than my 275 Sumitomos that I run on the front).
I ran them at about 17psi this past weekend. They hooked great and made me bog down some after launch until I got used to them.
I guess I will keep an eye out for some shorter DRs. I think I know of a few peeps that can use these to their full potential.
way too big for you hp level. you need nothing bigger than a 26" tire. you could even get away with a 27", but really need a 26. get some 15" wheels, if your a cheap bastard like me then summitstars are for you, if you have a lil dough to spend the go with weld or bogart b/c they will give you more sidewall thus helping your launch and getting those times down
Here is a link to the album of when I put them on for the first time:
http://s253.photobucket.com/albums/hh67/pikuoff/DRs/
