stall help
Old Jul 15, 2009 | 11:31 PM
01snake's Avatar
01snake
Default stall help
well my t-3650 ate another clutch (spec stg 2) and my sincs are goin out so im gettin rid of this POS and putting in a C4 with trans brake etc..
now my car is full bolt ons and sometimes a 125 shot with 4.30 gears....what stall would be best for me?
i have read that i want to stay around 4k-4400 stall?
Old Jul 16, 2009 | 12:34 AM
socalwrench's Avatar
socalwrench
There are several factors the determine the best stall speed- the biggest are 1) weight of the car, 2) camshaft duration and overlap, and 3) rear gear ratio.
For a built small-block, with 4.10 in a SN95- I'd say 3200 would be nice. 4000 seems high to me, that's a lot of slippage for the street.
Old Jul 18, 2009 | 02:25 AM
01snake's Avatar
01snake
stock 01 cams
as for weight...
-SRA swap
-trunk gutted to metal (no spare tire)
-rear seat delete
-MABY a/c delete and aftermarket k-memeber
gear is a 4.30
Old Jul 18, 2009 | 09:58 AM
steve0914's Avatar
steve0914
Originally Posted by 01snake
stock 01 cams
as for weight...
-SRA swap
-rear seat delete
gear is a 4.30
4k is too high, i would do 3200 like the other said, when you did your SRA swap did you get a 31 spline setup?
Old Jul 18, 2009 | 01:56 PM
01snake's Avatar
01snake
-eaton posi
-moser 31 spline axles
-TA girdle cover
i also did BMR adj. upper CA's and BMR lower CA's with spherical bearings all around even in the axle housing
Old Jul 18, 2009 | 09:57 PM
JJ03MustangGT's Avatar
JJ03MustangGT
your gonna hate those 4:30 gears on the street. id drop down to a 3:90 gear but thats just me. as for the stall id run a 3200 or 3600. perfect for the street and strip.
piotrek53
Oct 13, 2015 06:54 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
trashxtrash
Sep 20, 2015 10:49 PM
