Front end torque specs
Old Jul 26, 2009 | 07:50 PM
jvog's Avatar
jvog
Default Front end torque specs
Hey, does anyone know the torque specs for the K member, control arms, and struts. I took my old K member out today and bolted the new one up, but I need to torque it to spec. Also, do I need to use loctite? I noticed that it wasn't used from the factory so I think I should be good without it.
Old Jul 26, 2009 | 08:26 PM
945LSTANG's Avatar
945LSTANG
engine mounts = 111 lb/ft
lower k member bolts = 66 lb/ft
upper k member bolts = 85 lb/ft
balljoint nut = 129 lb/ft
sway bar bushing = 52 lb/ft
sway bar endlinks = 14 lb/ft
cotter pin bolt = 41 lb/ft
bottom strut bolts = 148 lb/ft
top strut bolt = 74 lb/ft
that should basically be it. let me know if you need any others and i will try to find them.
Old Jul 26, 2009 | 08:43 PM
jvog's Avatar
jvog
Thats great, thanks man
Old Jul 26, 2009 | 11:34 PM
jvog's Avatar
jvog
Loctite yay or nay?
Old Jul 28, 2009 | 01:59 PM
jvog's Avatar
jvog
I hadn't noticed you didnt list the control arm torque specs...what are they?
Old Jul 28, 2009 | 07:43 PM
945LSTANG's Avatar
945LSTANG
sorry...controls arms are 148 lb/ft.
i would say that loctite is up to you. im sure it would be fine without, but if you would like the peice of mind, then go for it.
Old Jul 29, 2009 | 08:41 AM
jvog's Avatar
jvog
Cool thanks, thats a lot of torque lol
Old Jul 29, 2009 | 05:16 PM
945LSTANG's Avatar
945LSTANG
+1
you better have a beast of a torque wrench. lol
you don't even want to know the hub torque specs on the IRS.
Old Jul 29, 2009 | 06:09 PM
Xemeth's Avatar
Xemeth
Torque spec for almost anything on any car (save things like head bolts, main caps, etc...) is tight. You're wasting your time torqueing down every bolt for everything. Just cause Ford has a torque spec for it doesn't mean you need to follow it.
Old Jul 29, 2009 | 09:25 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Dude you're wasting time layin under there tryna torque everything. Just run them in tight (using common sense) and be on your way.
