catback vs.muffler install
Old Jul 27, 2009 | 09:54 AM
5bites's Avatar
5bites
Default catback vs.muffler install
I just wanted your opinion on whether it's really worth it to buy a catback instead of just having the local muffler shop weld in some new mufflers. A guy should be able to save $100 or so going this route. Is their a significant gain with a catback?
Old Jul 27, 2009 | 10:02 AM
steve0914's Avatar
steve0914
all you gain is sound.... i like the sound of a catback better than just mufflers
Old Jul 27, 2009 | 10:35 AM
socalwrench's Avatar
socalwrench
There is a very small gain on a SN95 or S197 between a cat-back and an axle-back exhaust. The stock Ford mid-pipes flow fairly well.
Old Jul 27, 2009 | 12:35 PM
04CompetitionOrange's Avatar
04CompetitionOrange
Minimal gain. If you are strapped for cash, I would prob go that route. Maybe look at larger tips too, but just as an appearance mod.
Old Jul 27, 2009 | 10:13 PM
5bites's Avatar
5bites
Thanks fellas. I don't know which route I'll go. I like the idea of a clean bolt on catback but the muffler swap would maximize my budget.
Old Jul 28, 2009 | 04:11 PM
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
A catback tubing is 2.5" as compared stock 2.25." So with a catback you would get a little better performance, much better sound and it would let your car breath a little better.
I say go for the catback.
Old Jul 28, 2009 | 06:37 PM
grif62's Avatar
grif62
Well to let u know when I removed my stock catback it was heavy compared with the magnaflows, saved a little weight and loved the sound
Old Jul 28, 2009 | 06:47 PM
ct_white_stang's Avatar
ct_white_stang
Just get a cat-back....You won't be satisfied with just mufflers and you will want a midpipe and or headers at some point and wishing you had gotten the cat-back. Plus unless you know how to weld you have to factor the install cost whereas a cat-back you can do in the driveway.
Old Jul 28, 2009 | 08:58 PM
5bites's Avatar
5bites
I think this is the route I'm going. Thanks for the advice!
Old Jul 28, 2009 | 09:10 PM
Lowtryx's Avatar
Lowtryx
Definitely spend the money on the Cat Back. You get what you pay for, and as was previously said, you're going to simply regret it and want to get a mid pipe or headers later, anyway..
If not for the budget which as you said will suffer from purchasing a cat back, do it for piece of mind. I replaced the Exhaust Engine to Tip on my Stang and I wouldn't have it any other way.
