I WOULD SUGGEST SOME GEARS. A NICE SET OF 4.10's OUGHT TO DO THE TRICK. YOU SHOULD CONSIDER DRAG RADIALS IF YOU GET GEARS, THAT IS IF YOU WANT TO TAKE FULL ADVANTAGE OF RUNNING A GEAR.
DO YOU DRAG RACE AT THE DRAG STRIP? IS YOUR CAR A DD?
make sure you get a metal intake manifold with nitrous though...had 3 friends blow theirs to pieces recently because of missed shifts...id just save the money for a supercharger after you do gears and longtubes.
