Chassis Set-up Results
Some of you may remember this thread from a while ago.
https://mustangforums.com/forum/4-6l...she-weigh.html
Well the results are coming in and they are pretty good!. Last night after a warm-up pass to clean the tires after their 60 mile trip to the track I had a string of 1.57, 1.58, and a 1.56! Not too bad for a DOT tire driver to and from the track.
Not bad at all. Your previous best was a 1.59 right? So I assume that when you say "after a warm-up pass to clean the tires", you didn't do a normal burnout for any of those 3 passes? How was track prep, did you run your usual tire pressure?
The first pass was with an extensive burnout ( 8-10sec )to clean the "skin" off the tires from the highway miles. My other burnouts were a 3-5 sec smoking as usual. Even with the tires too hot and in 90* direct sun it still got a 1.65!. Track prep was normal (poor) for a street tire race night, I did drop the pressure to 13* after the first pass and kept it there all night. Yes, my previous best at this track was a 1.59.
Sep 24, 2015 09:18 PM
Sep 17, 2015 07:57 PM
