injector question
Old Aug 9, 2009 | 02:50 PM
school boy's Avatar
school boy
Default injector question
i have a 01 mustang gt and i was wondering what kind of horsepower #s will requiring bigger injectors?
Old Aug 9, 2009 | 02:53 PM
disposablehero27's Avatar
disposablehero27
if you go to rpmoutlet.com and check out the injectors for sale, they rate to what horsepower they support. if you haven't done ALOT of work, you don't have anything to worry about. engine work or forced induction.
Old Aug 9, 2009 | 03:10 PM
mrtstang's Avatar
mrtstang
Your stockers are good for a tad over 300 rwhp.
Old Aug 9, 2009 | 03:58 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
If you set an 80% duty cycle limit (rule of thumb max) the 19lb/h orange injectors max out at 244 HP or so, this is why Ford went to the pink 21lb/h injectors (268HP @ 80%) in late 2001.
There's no way the orange 19lb/h injectors will make 300HP, even at 100% duty cycle as Ford runs them at 40 psi rather than the 43.5 psi conventional test/specification pressure.
Old Aug 9, 2009 | 04:33 PM
school boy's Avatar
school boy
ii'll check the injector size but heres the parts list i have.. what you think? hp?
shorty headers
offroad x pipie
cat back
al pulleys
clod air intake
Pro-Series Coil Pack
typhoon intake manifold
sniper software programing
this stuff is sitting in my garage waiting for install,
on the way
75mm tb
intake plenium
90mm maf
Old Aug 9, 2009 | 05:02 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Get some pink 21lb/h OEM (they'll be pushing 90% dc), or better yet 24lb/h after market injectors, and you'll be all set. 30lb/h would work but may be troublesome to tune at idle and low loads.
Old Aug 9, 2009 | 05:07 PM
school boy's Avatar
school boy
i know i will either turbo the car or put the stage 2 comp cams sometime early next year. how would this affect me choosing injectors?
Old Aug 9, 2009 | 05:39 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
You will need to buy higher capacity injectors when you do that--injector sizing is not something you set up now for future plans, unless you like banging your head into a wall. You need to size them so that they will be operating at 75% to 85% duty cycle at you current maximum engine output.
When you go f/i you can bump fuel pressure using a BAP or more properly line things up in the tune, or use larger injectors to accommodate the added air.
Old Aug 9, 2009 | 09:28 PM
school boy's Avatar
school boy
hey thanks guys!
Old Aug 15, 2009 | 11:28 AM
stang2009's Avatar
stang2009
My 2009 GT has purple injectors. What size are these?
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
treesloth
Sep 28, 2015 07:03 AM
MacSerio
Sep 27, 2015 01:05 PM
