brake experts
Old Aug 10, 2009 | 02:51 PM
mvr's Avatar
mvr
Default brake experts
so im am going to buy a new set of calipers/pads/rotors for the front. most likely either the bullit/mach1 set or the 10th anniversary cobra kit. il also get new rotors and pads for the back. my question is whats the difference between the special edition calipers and the cobra calipers? also should i get slotted rotors or go with the 13in flat rotors that come with the kit.
im looking to get the kits from buyfordracing.com here are the kits i am comparing.
bullit/mach1
http://www.buyfordracing.com/shop/pr..._id=688cPath=6
10th ann cobra
http://www.buyfordracing.com/shop/pr..._id=673cPath=6
they also sell just the calipers of each set at the site incase i wanted to go with different rotors.
any help?
Old Aug 10, 2009 | 03:01 PM
masterofthepuppets99's Avatar
i need new calipers on my front and i was thinking of buying this one http://www.latemodelrestoration.com/item/LRS-2300RR
its a little more in cost but i think its the complete kit. i am wondering if the first link you posted is a complete kit also or am i going to have to source parts. because i need to buy calipers soon
Old Aug 10, 2009 | 03:09 PM
mvr's Avatar
mvr
i dont think it comes with the lines or the bolts but otherwise its the same. im not sure how much it would be to buy those thing separately than the kit.
Old Aug 10, 2009 | 03:18 PM
well if i used buyford racing parts.com and got the cobra 10th anniversary kit with calipers, rotors, stainless steel braided brake lines, and banjo bolts and washers, and pads. then it will total about $400 whereas latemodelresto.com is like $540 and americanmuscle.com is more like $670
Old Aug 10, 2009 | 03:23 PM
bullit/mach1
10th ann cobra
any help?
well from what i can tell is that you are buying the cobra logo on the side of the caliper and nothing else. there is only a, what, $30 dollar difference
Old Aug 10, 2009 | 06:10 PM
hpwrestler220's Avatar
hpwrestler220
there is no difference between 03/04 brakes, bullitt brakes, 99/01 brakes, or mach1 brakes.. they are all the same thing. 13" rotors with calipers to account for the rotor size...
i would just get the ones with the pony on them... no point in having them say cobra... kinda gay if you dont have a cobra, but all of those brakes are the same... make sure you get the SS lines.. and the 1st kit doesnt say u need to buy banjo bolts... so thats $14 saved
Old Aug 10, 2009 | 06:13 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Also, 96-98 are the same brakes, and I believe 94-95 Cobras had the same brakes as the ones you just listed.. I could be wrong on this
Old Aug 11, 2009 | 12:05 AM
mvr's Avatar
mvr
yeah i was pretty sure they were the same exact thing.
should i buy the kit that comes with the rotors? or should i get aftermarket rotors?
Old Aug 11, 2009 | 12:50 AM
Young_Buck's Avatar
Young_Buck
It depends on what you want to do with the car.
Is it gonna be your DD or drag only if so go crazy with some cheap drilled good looking rotors from brakelabs, 175 shipped for all 4 rotors.
If your gonna auto x stick with the brembo that comes with the buyfordracing kit. If your gonna go hardcore get some good quality drilled rotors.
Im quite sure most or all of the 13in and 11.65in rotors are slotted.....right
Old Aug 11, 2009 | 01:09 AM
mvr's Avatar
mvr
car is a DD that sees some track use. eventually it'll have a vortech on the car.
if i buy rotors elsewhere, where is a good place to get quality stuff. i hear alot about cheap ebay stuff going bad or cracking.
