Upgrade for rearend!!!
Old Aug 15, 2009 | 12:04 PM
jeff37110's Avatar
jeff37110
Default Upgrade for rearend!!!
Well, I havent had any luck with drag radials..So I am planning on slicks in the near future..I only drive the car on the weekend,so its not a daily driver..I ordered some Moser 31 spline axles with wheel studs and a new locker with carbon discs.. Is there anything else I will have to purchase to prepare for slicks... Im thinking maybe better u-joints while im at it...Thanks in advance for any advice..Im running 3.73 gears also..Should I maybe run a lower gear???
Old Aug 16, 2009 | 09:40 AM
jeff37110's Avatar
jeff37110
ANY Advice???
Old Aug 16, 2009 | 09:59 AM
JayC's Avatar
JayC
Originally Posted by jeff37110
ANY Advice???
Go with a 26" tall slick, have the torque boxes and axle tubes welded , set it on the rev-limiter and launch.
P.S. HOLD ON!
Old Aug 16, 2009 | 05:02 PM
jeff37110's Avatar
jeff37110
Do I need to get the axle tubes welded while all componets are out of the rear end?? Thanks for advice JayC
Old Aug 17, 2009 | 06:32 PM
jeff37110's Avatar
jeff37110
Old Aug 17, 2009 | 08:46 PM
JayC's Avatar
JayC
Nope it can be done intact. You will need to pull your rear seat to check for hot spots when welding the torque boxes.
Old Aug 18, 2009 | 09:18 PM
jeff37110's Avatar
jeff37110
Thanks. Its on the list to do this weekend..
PaulH2
20
Jan 31, 2016 09:48 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
