trick flow
They are pretty aggressive for stage 1 cams. I talked to Trick Flow about these grinds, and they highly recommended upgrading the springs. The guy i talked to told me they were good for around 25 hp, but who knows in reality!
I was very interested in these until i came across Bullet Racing Cams, which are the ones i'm going with.
thinking about doing heads later (they come with springs) so im looking the most agressive cam i can get without changing springs. i know ill have to keep it below 6000 rpm but really want the lopey idle more than anything.
You need to change springs with ANY aftermarket cam - I don't care what the manufactuer says.
I mean come on - what is another 600 bucks for insurance and knowing that you're not gonna drop a valve and jack up your engine?
My .02
My .02
If the lift is close to stock, and you are not revving past 6k, it really is not necessary. It certainly isn't a bad idea, but there is not much benefit if the cam is structured right.
seems like stiffer springs would beat the valve seats in head worse also.
but i may do springs and stage 2's because 2 grand for new heads that are only worth about 35 horse seems like a lot.
From the numbers iv seen posted from now 2 ppl the bullet cams are pretty lame.
With stock heads(if u plan to stay with stock heads) hi-techs own. You dont have to change out springs, but you should change them out regardless of stage or what the company tells you.
This.
