new problem help
Old Aug 28, 2009 | 01:01 PM
1999mustang2000's Avatar
1999mustang2000
Default new problem help
changed the plugs and thermostat..now when i rev the car let the rpms come down a little then rev again it pops real loud in the exhaust
Old Aug 28, 2009 | 03:29 PM
devongarver's Avatar
devongarver
Sounds like its backfiring, unburnt fuel in the exhaust is igniting...
Old Aug 28, 2009 | 04:13 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
backfiring thru the intake or exhaust? Are the plugs tight? Did it blow a plug out? Anything is possible
Old Aug 28, 2009 | 04:15 PM
89gtwith3.55s's Avatar
89gtwith3.55s
headers could have a loose bolt too
Old Aug 28, 2009 | 04:36 PM
1999mustang2000
plugs are tight but i did have a bad o ring when i started the car and fuel squirted out a little so im not sure if maybe some got down in the plugs or if maybe some of the coolant got in them from where i changed the thermostat..
and backfiring through the exhaust
Old Aug 29, 2009 | 12:29 PM
1999mustang2000
ok got the backfiring stopped but now it misses like crazy
Old Aug 29, 2009 | 12:31 PM
fisher2985's Avatar
fisher2985
was everything good before u changed the plugs?
Old Aug 29, 2009 | 12:39 PM
1999mustang2000
yea it had a little miss before
Old Aug 29, 2009 | 12:44 PM
fisher2985's Avatar
fisher2985
u probably got a bad coil then. if the check engine light is on take it to advance. (they will scan it for no charge) any code between a p0300 and p0308 is cylinder misfire. (ie p0304 is cylinder # 4 misfire. then u will know which coil or coils to look at. also what type of plugs did u use?
Old Aug 29, 2009 | 01:11 PM
1999mustang2000
autolite double platnum
