wingless question
Old Sep 4, 2009 | 09:45 AM
russell16's Avatar
russell16
Default wingless question
When you put the silicon around the plugs, if you want to put your wing back in, does it mess up your paint? i like the wingless look, but until i can take it to a shop there will be times i want to put it back on. just want to make sure it wont mess up my paint. Thanks.
Old Sep 4, 2009 | 10:20 AM
99BlackPonyGT's Avatar
99BlackPonyGT
aka 'Negative Nancy'
i didnt even use plugs...i used electrical tape....small piece covering holes on outside, and small piece on inside....looks like hell, but it will hold up just fine until you decide to put it back on or have the holes filled
Old Sep 4, 2009 | 02:12 PM
devongarver's Avatar
devongarver
hahha, plugs, my holes are open lol. But no, if you use "water clean up" silicon, you should be fine. The chemical clean-up styles are much more invasive with paint. What you should do, if you are THAT concerned, is only silicon from the bottom side of the the trunk lid. Have you taken the wing off to look at the trunk lid yet? Its likely going to have many imperfections underneath the mounting brackets on the decklid.
Old Sep 4, 2009 | 04:27 PM
loweredfourpointsix's Avatar
loweredfourpointsix
my plugs fit snug. i wrapped a piece of electrical tape around the rear plugs bcuz the holes are bigger and it fits fine.
Old Sep 4, 2009 | 09:17 PM
russell16's Avatar
russell16
Yeah, i have the imperfactions which is why if i go to a show or something i will put the wing back on so that way they can't see them.
Old Sep 4, 2009 | 09:49 PM
loweredfourpointsix
claybar takes most of it out. it just takes a lot of work
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
