LT Headers installed with O/R H-Pipe
Just had to put up a post since I just got this project finished. Headers are a pain in the a$$. That being said, if you are planing on doing LT's, you will most likely be dropping the K member. Get a tubular one. Wish I would have.
I love the sound of my car now, the only issue I have to sort out is with the LT's my steering shaft/column is rubbing up against my header. Think it might be time for a little bet of a hammer to fix that. -Riggs |
Awesome man! Im lookin at headers soon too!
Now get that PI swap!! haha |
When will you be posting the video of the new exhaust?
Originally Posted by Riggs
(Post 6486004)
Originally Posted by fisher2985
(Post 6486522)
u can adjust the steering shaft before u break out the hammer. the shaft is designed to slide in and out(probably just stuck) so u can get the steering u joint off of the header.
(Post 6487325)
I'm going to be working on that issue tomorrow. I'll have to see if that will give me enough clearance.
question for you guys with LT's. Lets say you have the exhaust setup you want out back and you are ready to swap the stock manifold out for LT's. Does the sound change much? Enough to be worth the money?
Originally Posted by Roush2002
(Post 6487699)
Originally Posted by mrtstang
(Post 6487706)
Well, i guess it's a matter of opinion. It was for me. The long tubes alone had a slightly deeper and smoother idle, and under WOT it sounded much more beast like...quite a bit louder and deeper.
Is it pypes the only company that has this problem?
If not, do you think ARH will have this problem? |
