How many of you run in 5th gear?
Old 10-14-2009, 06:40 PM
scooter3
scooter3's Avatar
Default How many of you run in 5th gear?
My commute to work is almost all highway and about 25 miles one way. I usually always run in 5th, but the car really has no passing power when I need it. The car seems to really like running in the higher RPM range and is much more responsive. I understang the whole gas mileage thing and that is not a big concern. So how many of you run in 5th on the highway?
scooter3 is offline
Old 10-14-2009, 06:42 PM
JDraper
JDraper's Avatar
On the highway, all the time with both Mustangs.
JDraper is offline
Old 10-14-2009, 06:43 PM
BraMas
BraMas's Avatar
I run in 5th on the HWY. But I have 4.30's
BraMas is offline
Old 10-14-2009, 06:44 PM
945LSTANG
945LSTANG's Avatar
anything over 50mph is 6th gear. if you need to pass someone, just downshift to 4th or 3rd.
945LSTANG is offline
Old 10-14-2009, 06:57 PM
nascrchi
nascrchi's Avatar
you're lazy man! lol just down shift.....and GUN!
nascrchi is offline
Old 10-14-2009, 07:05 PM
mvr
mvr's Avatar
... lol thats why they made a 4th gear.
stock gears? mine pulls pretty good enough in 5th at highway speeds with 3.73
mvr is offline
Old 10-14-2009, 07:43 PM
Mustang_NTriangle
Mustang_NTriangle's Avatar
u must have stock gearing and 3.27s suck. 5th gear you have no passing power. Go with different rearend gears will make your 5th gear have more passing power due to the higher rpms. Your choice 3.73s or 4.10s. I recommend 4.10s and if you were like me when stock with stock gearing I was running in 4th gears on the highway so much I did not really lose any gas mileage with my 4.10s because i never needed to drop gear in 4th unless i was racing. I had a 80 mile commute round trip.
Mustang_NTriangle is offline
Old 10-14-2009, 08:19 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
The first thing I noticed when I got my '03 GT was that is was A LOT slower than my M45 Eaton equipped '92 Miata (12 psi)--made me realise why I always ate up Mustangs on the boulevard. I learned to drive it as a 4-speed unless I was cruising.
Now with 3.73's, intake and exhaust mods, and a tweaked 93 octane tune, it's a bit faster than the Miata--mostly because it hooks up better. The Miata was light, had a viscous LSD, and had some real tire size issues...
cliffyk is offline
Old 10-14-2009, 08:52 PM
scooter3
scooter3's Avatar
LOL! Unfortunately with old age, laziness occurs. I don't mind downshifting it just requires more energy on my part when i can let the car do all the work! LOL.
scooter3 is offline
Old 10-14-2009, 08:55 PM
scooter3
scooter3's Avatar
Actually gears are on my wish list. That and a sniper tune. With as much highway driving I am doing it is a matter of which gears to put in. 3:73 or 4:10's. Again mileage is not a concern nor is drone which I already have. I just want more power and reliability.
scooter3 is offline
Quick Reply: How many of you run in 5th gear?
