Suspension Setup
Old Jan 21, 2010 | 10:09 AM
lilcrate's Avatar
lilcrate
Default Suspension Setup
Here is the possible setup. Opinions please.
In garage waiting for install
tokico hp blue shocks and struts
mm caster camber plates
bbk isolators
hr ss lowering springs
thinking of adding before installation
mm LCAs on AM
steeda ball joints
already have flsfcs
opinions?
Old Jan 21, 2010 | 10:15 AM
ddmsgtr1's Avatar
ddmsgtr1
What are you trying to do with the car?
Old Jan 21, 2010 | 10:22 AM
lilcrate's Avatar
lilcrate
Good looking/driving street car with the occasional strip.
Old Jan 21, 2010 | 10:36 AM
teej281's Avatar
teej281
4.6L Section Moderator
No handling or twisty taking??? How much are you wanting to spend on your suspension??? For me, the suspension setup that i want is the Bilstein HD's from AM, front and rear coilovers from MM, and extreme duty lower control arms from MM. That setup would be great for track and street and will handle with the best of them. But then again, im more about handling and ride comfort, which is why im going with coilovers.
Edit: H&R springs are great looking lowering springs but they will hurt your launch at the track and might ride a bit on the rough side.
Old Jan 21, 2010 | 10:44 AM
lilcrate's Avatar
lilcrate
^When I think about it I feel like I would want to handle good, but honestly I don't think I have ever tried to take a turn fast. So twisties are out. Not wanting to spend a lot on suspension, just a decent setup. HRSS will hurt launches over stock?? Not really wanting to swap out anything I already have, just wondering what will go well with what I already have.
Old Jan 21, 2010 | 10:52 AM
teej281's Avatar
teej281
Oh, gotcha. I was thinking the first list was stuff you wanted to buy...pays to read the headings. lol The H&R SS springs will hurt launch over stock because of the higher spring rate of the springs. They wont allow for weight transfer like stock springs will.
But as far as the lower control arms go...YES!!! Buy lower control arms, but i'd go with the extreme duty ones direct from MM. They are solid bushings on both ends with urethane bumpers surrounding the solid bushings so they arent that noisy. That'd be my suggestion to you. Those are the LCA's i plan on going with.
Old Jan 21, 2010 | 11:01 AM
lilcrate's Avatar
lilcrate
^ok, i will check them out, do you think the balljoints are worth it?
Old Jan 21, 2010 | 11:08 AM
teej281's Avatar
teej281
I'd get the steeda balljoints and the MM bumpsteer kit should be done. MM makes 2 bumpsteer kits. The tappered stud type is the one you want if you have a stock k member. But I would suggest both of those to you when you get the lowering springs put in.
Old Jan 21, 2010 | 11:33 AM
lilcrate's Avatar
lilcrate
this?
http://www.maximummotorsports.com/in...dex&cPath=3_13
And which control arms are you talking about, they have a ton on there?
Old Jan 21, 2010 | 11:41 AM
teej281's Avatar
teej281
yea, the ones listed on that page are the ones i'd look into. The ones for our year cars with the tappered studs. And the control arms that i suggested are under the extreme duty standard control arms and its the ones with spring perches and swaybar mounts for 99-04.
