Winter plans= Water/Meth kit,RR SC Pulley,Maintenance,tires etc
Old 02-11-2010, 11:46 AM
jivepepper
jivepepper's Avatar
Default Winter plans= Water/Meth kit,RR SC Pulley,Maintenance,tires etc
Winter plans= Water/Meth kit,RR SC Pulley,Maintenance,tires etc.
First of all, I'm most excited by the AIS(Alcohol injection systems) Stage 2 competition trunk mount kit. I will be running a 3 nozzle set up. One small one before the head unit and the other 2 small ones close to the throttle body.
I will be running a 49/51% Methenol to water mix. The one nozzle will help control temps at the Compressor, since I plan on spinning it pretty hard, and the two nozzles at the TB will finish cooling the iat's while also adding octane. In addition to my FMIC setup. This allowing for me to run 20+* of timing while on 93 octane fuel. All without using the expensive torco race gas concentrate I do now @ $20 a can. Even though my everyday tune is only 27 hp less @ 638 than the torco tune. It's lazy under the curve becuase it only being 15* of timing compared to 20* on the torco.
Even though their kits have always been great their new competition tank is even slicker, concealing the pump underneath and the new tank holds 3 gallons instead of 1.5. It also has a provision for an extra pump, if needed, for super high hp applications.
I will also be running a progressive controller. That allows for a onset boost level and high boost setting where it hits full capacity.
It's on it's way and I can't wait to get my hands on it.
Pic of the kit. Minus the tri nozze upgrade. I will take detailed pics as soon as it shows up. The terrible winter storms this year are slooowwing every thing down.
http://www.alcoholinjectionsystems.c...c37/index.html
I ordered a 8 rib Reichard Racing 2.8" supercharger pulley. I'll be spinning the **** out of the SC so I will see how much the kit helps.
I'm also replacing one of the o2 sensor extenders because it was melted against the headers. Plus the o2 sensors, spark plugs, oil change along with a retune.
I bought some cheap Sumitomo tires. 315/35/17. I've had them before. I hated how huge the thread gaps were. But since I plan on running 15" wheels next year at the track I got them. I'm just tired of buying DR's every year
jivepepper is offline
Old 02-11-2010, 12:05 PM
teej281
4.6L Section Moderator
teej281's Avatar
So you know even us at stock horsepower dont hook with those things lol so what are your power goals with this new setup if you dont mind me asking??? And nice to see you coming back around here. its been a while.
teej281 is offline
Old 02-11-2010, 02:06 PM
lilcrate
lilcrate's Avatar
I bought that exact water/meth kit, car is in the shop getting it installed right now.
lilcrate is offline
Old 02-11-2010, 02:28 PM
bopiela
bopiela's Avatar
sounds like a good winter!
bopiela is offline
Old 02-11-2010, 02:58 PM
teej281
teej281's Avatar
Yea, really. lol
teej281 is offline
Old 02-11-2010, 06:53 PM
jivepepper
jivepepper's Avatar
That's cool, did you go with the progressive controller and tri nozzle set up?
Old 02-11-2010, 07:00 PM
03GeeTee
03GeeTee's Avatar
why did you post this in both the tech and general sections?
03GeeTee is offline
Old 02-11-2010, 07:31 PM
jivepepper
jivepepper's Avatar
it was an accident
Old 02-11-2010, 07:35 PM
lizzyfan
Underboss
lizzyfan's Avatar
Have not heard from you in awhile jive
lizzyfan is offline
Old 02-11-2010, 07:38 PM
jivepepper
jivepepper's Avatar
Very busy with a sick mother. Driving 4 hours each way to Johns Hopkins hosp. Is there anyway to merge the other thread that I accidently started in the other forum.
Quick Reply: Winter plans= Water/Meth kit,RR SC Pulley,Maintenance,tires etc
