how much better traction?
How much better traction will a 17x10.5 get compared to a 17x9 granted they have the same tire on? I do think the 10.5s look much better but between the rims and tires they are significantly more expensive.
I don't even think you'll notice a difference to be honest. I've had both 275's on a 9" rim, and 315's on a 10.5" rim (both with the same Sumitomo tires) and it didn't make any difference in terms of traction.
Yeah, i know the sumis suck regardless of the width, but i would've thought there would be a slight difference by going wider.
Theoretically there should always be slight difference (regardless of the type of rubber) when running a wider tire, but who knows lol.
That's what I figured. I just need some new tires BAD. the car came with the wrong size tire when I bought it (235/55-17) and they are terrible on top of that. When I shift into second at WOT I almost lose control every time lol
When I swapped from a 245 to a 275(when I got the cobras) The car had a little better traction.. not much though. It did keep the 4.10s at bay a tad better in 1st gear but other than that nothing to write home about.
Yea, when i went from a stock wheel to an 18x9.5 inch wide wheel, i felt it hook better. It was probably just due to the tires being nittos over toyo fz4's or whatever the stock wheels have on them. But you will notice a slight bit more traction going from what you have now to 315's on a 10.5 wide rear tire.
