Found an engine, what to do?
Old Feb 23, 2010 | 07:20 PM
stevland's Avatar
stevland
Default Found an engine, what to do?
I have a 98 gt npi and I found a 99 gt pi motor for $300 and the bearings need to be replaced, so heres the question; Do i just swap out the heads and build on the npi motor, or just replace the bearings on pi motor?
What would you do?
Old Feb 23, 2010 | 07:25 PM
jvog's Avatar
jvog
What would you do?
I would swap out the heads and build on the npi motor or find a good pi motor. I wouldn't buy an engine that needs bearing because who knows if the metal shavings from spinning the bearins messed up anything else. The crank could need to be worked/replaced, and the cylinder walls may be scratched and need to be bored or honed.
Old Feb 27, 2010 | 05:43 PM
stevland's Avatar
stevland
since I will have an entire engine, I dont really need a kit do I? I would have everything I need for the head swap. Right?
Old Feb 27, 2010 | 06:25 PM
JC316's Avatar
JC316
Yeah, I would toss the PI heads and intake on the NPI motor. More compression and a better motor to start with. The PI motor will need likely need a new crank. You will have to get the ford head changing kit with the gaskets and bolts, but yeah, it should be about all.
Old Feb 27, 2010 | 06:39 PM
stevland's Avatar
stevland
I know I would need a new set of gaskets, but would i be able to take the bolts from pi engine?
Old Feb 27, 2010 | 06:50 PM
Chris98Gt's Avatar
Chris98Gt
No, the factory head bolts are tty (torque to yield) which means they are unusable after they have been torqued. You can use the other bolts like intake and stuff just not the head bolts, main cap bolts, or rod bolts. supposedly the crank and cam bolts aren't to be used again either.
Old Feb 27, 2010 | 09:27 PM
stevland's Avatar
stevland
good to know, I was completely unaware of that. thanks
Old Feb 27, 2010 | 11:15 PM
jvog's Avatar
jvog
If you buy the ford head changing kit as mentioned above, it comes with new bolts.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
mtxplod
Aug 29, 2015 01:43 AM
rocket22
Aug 28, 2015 07:08 PM
Nexuia
Aug 23, 2015 11:30 PM
