Base idle settings
I have a 2001 GT automatic, the idle is currently set at 450 in drive and 650 in neutral, seems a little low to me, I'm going to bump it up with my tuner, but I am wondering if anyone knows what the factory idle settings were.
When you do, disconnect the battery while you are installing it (5 to 7 minutes). this will clear the KAM (Keep Alive Memory) and force the PCM to re-learn the idle air trim values.
The settings were changed in the tune? It should be 560 in drive and 736 in neutral, if the PCM was not maintaining these settings then it is most likely the IAC is sticking or stuck--have you received and installed the new IAC yet?
Thanks shadowdrake !!! I've been asking around different sites/forums for the base idle setting for months and nobody knew it.
I guess my car is idling fine then. In drive it idles around 550 and in neutral/park 700-730. I always thought this was kinda low....?? Thought about adjusting it. Guess i was wrong. Thanks again. Now i can sleep at night.
stangin1996gt
Sep 21, 2015 11:01 AM
trashxtrash
Sep 20, 2015 10:49 PM
mungodrums
Suspension
Sep 7, 2015 07:22 PM
