problem with my car :/
Old Apr 12, 2010 | 12:25 PM
RyanK's Avatar
RyanK
Default problem with my car :/
I need some help with a problem that my car got all of a sudden, when i start it up it idles fine and drives ok but once it warms up and it idle's it like miss's bad you can feel it then if you start to accelerate it only gets going hard after about 2000 rpms but from idle to 2000 its like its getting less than enough fuel and idk what could be causing it do y'all have any ideas?
Old Apr 12, 2010 | 01:26 PM
noroofonthecoupe's Avatar
noroofonthecoupe
Gimme a cupcake & a pat on the head
mine was missing too when I bought it, I changed the spark plugs and realized one of the wires was burnt out I was only running on 7cyl or less. I'd suggest checking basics like that its real easy to check...
Old Apr 12, 2010 | 07:18 PM
timthegreat1's Avatar
timthegreat1
yeah probably spark plugs man
Old Apr 12, 2010 | 08:49 PM
98redstang's Avatar
98redstang
how many miles do you have? I would do plugs, wires, fuel filter clean your iac and go from there.
Old Apr 12, 2010 | 09:07 PM
02stang2113's Avatar
02stang2113
Give it a complete tune up
Old Apr 12, 2010 | 10:31 PM
RyanK's Avatar
RyanK
i got 125k on the odometer, but yeah im taking it to get a tune up soon i just have to get my taillight fixed witch is already being shipped so im good.
Old Apr 13, 2010 | 04:41 AM
nascrchi's Avatar
nascrchi
sounds like the time when I didn't plug one of my wires after replacong the plugs(retarded I know). Could be something spark plug related.
Old Apr 13, 2010 | 05:52 PM
jheugatter's Avatar
jheugatter
I would check all spark related items and even check for vacuum leaks. Then check your coolant level. I'm reading to many people with the same problem including myself recently. Cracked Intake Manifold. Mine cracked at the heater hose and ran the same as yours. Studder until about 2000 rpms. Water was leaking into the #4 plug wire.
djbigskrilla
Sep 20, 2022 01:04 AM
FD725
Aug 23, 2015 06:43 AM
jjwinel78
Aug 17, 2015 03:34 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
