PATS problems
Old Apr 15, 2010 | 03:39 PM
stangalator's Avatar
stangalator
Default PATS problems
Been searching for this issue but I have had no luck. My theft light blinks at me when i first start the car. It continues to run fine with no issues, but after a while the light stops blinking fast and blinks slow giving one blink... pause... 6 blinks... longer pause then it continues blinking a 1-6 code. Is this an error code, if so what error is it?
I recently had a engine code when I had my mid pipe off so I cleared it by unhooking the battery and touching the terminals together for a few seconds. It started after that. Any ideas?
Old Apr 15, 2010 | 03:51 PM
stangalator
Found out the codes, 1:6 means "Faulty link between PATS module and EECV"
http://www.fordscorpio.co.uk/pats.htm says go to dealer to get it fixed.
Is there something I can do? maybe reflash it?
Old Apr 15, 2010 | 07:26 PM
Mustang_NTriangle's Avatar
Mustang_NTriangle
try disconnecting battery for a 1/2 hour and retry. If that does not work reflash your car to stock tune to see if problem goes away then reflash your performance tune.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
03blackwidow
Sep 20, 2015 02:36 PM
