my new engine block
i just got this block, here are the specs and pics i have, let me know what you think and if yuo would change anything.
The motor is a MMR Pro MOD 900 shortblock.
Cast Iron 2004 Cobra Block, torque plate bored and honed, 4340 Forged 3.543 stroke Cobra Crankshaft w/micro polished journal,4340 5.933 manly H-beam Rods w/ARP rod bolts ( These rods are shotpeened, magnafluxed and weight matched, Forged Manley -18cc pistons,Speed Pro file fit rings filed for forced induction, Clevite tri-metal Rod and ACL Performance Main bearings
Complete Pro Assembly and Balanced.
i was thinking between 600 and 650rwhp, i should be happy with that. I dont know much about building an engine but this is a start, got a lot of research to do and figure out how i am going to do it. Going to try and reuse as much as i can from my car now but it prob wont be much, just have to figure out what will work on my car and what works with each other.
Did that come out of a 4v car??? Im wondering just because it has 2 piston notches on it making me wonder because you usually only see the pistons notched for one valve on the intake side, or am i just not observant to see the one for the exhaust valve on usual setups? If it is for a 4v, be careful on the cam choice so you dont run into ptv issues as the pistons arent notched for a 2v...but thats only if it was a block built for a 4v. If it is in fact for a 2v head, then you can run pretty big cams and not have to worry. but looks like a great start. what blower you gonna run to get to those power goals???
the guy who had it before me had blower cams on it but no blower, the cr on it is 8.9.1. I dont know much about that but he was setting it up for a blower just didnt have the funds to finish. I will put my vortech on this since i have it. I believe he had it set up as a 2v, here is what his sig was at.
1998 mustang GT
MMR forged shortblock 8.9:1 comp
MMR stage 2 heads,Crower stage 2 blower cams ,Edelbrock intake,dragon 100mm Throttle body,HPP racing Sheetmetal upper plenum,Demolet 110mm CAI,Meizere electric W/P,BBK ceramic long tubes
1998 mustang GT
heres everything he had for sale, let me know if this stuff is any good and i might buy some more off of him
-3 bolt timing cover with fairly new steel 3 bolt tensioner!! Great shape!! $175
-MMR forged 900 shortblock( fly cut forged manly -18cc pistons, forged rods, forged steel crank) great shape!! $1300
-crower stage 2 blower cams with cam gears. journals in good shape $375
-MMR stage 2 ported Romeo PI heads/crower high load springs/retainers$950
-cobra high volume oil pump good shape$125
-Edelbrock intake setup COMPLETE!! Edelbrock intake, fuel rails, HPP upper plenum, dragon 110mm throttle body, demolet custom intake, 90mm MAF calibrated for 30#injectors, throttle cable to fit setup, all vacuum hoses and fittings. EGR block off plate. everything is great shape!! a steal at $850!!
-BBK ceramic long tube headers. Fair shape alittle miss colored and light scratches. flanges all straight and good shape. $350
-VRS Offroad X pipe for BBK LTheaders good shape $125
-BBK O'R H pipe for BBK LT headers fair shape with a dent in the crossover$ 80
-Meizere electric water pump good shape$225
-FRPP AC delete $30
-Moroso 7 quart oil pan good shape $160
-MSD coilpacks and 8.8 wires good shape$ 150
-Ford racing 30# injectors good shape$200
-vortech 255lph direct fit fuel pump for 98 gts$70
-sct XCAL 2 tuner not locked$275
-magnaflow magnapack catback96-98GTs good shape$300
-Moser 31 spline steel axles great shape! $180
-ford racing 4.10 gears with New Cobra tracloc diff$200
-96-98 GT t-56 6 speed D+D CONVERSION SETUP!! Included cobra T-56 with mechanical speedo output, custom aluminum driveshaft, extended range speedcal, MGW shifter, Cobra shift ****, cross member. All you need is the brackets to attached to the subframes. Well over $3000 here selling for $2,000
-Fidanza aluminum flywheel. Needs new insert. summit has them for $65 I'm selling as is for $120
-MAC diff support cover great shape!$85
-COMPLETE cobra 13" cobra front brake setup and 11.65" rear brake setup. Rotors stainless lines, good pad life. Everything great shape!! Rotors inside are alittle rusted due to not be treated when made I guess. $425
-MM solid steering shaft! Good shape just alittle rusty $165
-HOtchkis Upper+lower control arms. uppers are adjustable lowers arent. Good shape.$250
-KILLER DEAL HERE!!
Summit start 15x4" front drag wheels with kumho tires, summit star 15x8" rear wheels with MT 275/50 drag radials, Included is the front hub centric 1" wheel spacer by stang suspension(now out of business) Only used at the track those 7 passes. Excellent tread left on tires rims in excellent condition. $600
-Black headlights in great shape. No corners.$100
-Kaenan S-281 wing GREAT shape nice glossy black paint $160
ANOTHER STEAL RIGHT HERE!!
-MPH returnstyle COMPLETE bolt in and ready to go fuel system off there 919RWHP record 2v street car 2000hp capable. All you need is fuel rails. SPECS! Aeromotive pro series fuel pump, aeromotive duel fuel coolers, Aeromotive Fuel pump controller, Custom baffled and sumped tank, aeromotive FPR, all stainless lines 12an feed and 8or 10an return, fittings, clamps to attach to car vacuum lines. The works just bolt in and go. quickest easiest way to a safe strong fuel system. asking $1100. if you total up all those parts this is quite a deal! the pump alone is $650 new.
Also a whole bunch of original parts, dash, cluster, passenger leather seat, back leather seats, ect ect! just ask me!
Ok Like I said most parts are still in the car but if interest is showed for one part I'll make my best attempt to get it out cleaned and pictures taken. I'm not trying to make a bank here I just need to get money to help my dad. he help me build this so its only right to use this to help him at all possible. Thank you. Feel free to contact me on here, email, or by my phone. Thank you all so very much!!
-FRPP AC delete $30
-KILLER DEAL HERE!!
If it were me I'd put a set of main studs and mmr side bolts in it instead of using the factory stuff for that power goal. Also I didn't realize the 03-04 cobra blocks only had a 2bolt main setup. I thought all 4v cars had 4bolt mains and then the side bolts that both 2v and 4v have.
I'd look into that fuel system and the intake setup since you will be shooting for a real nice power goal. Also you should have asked him what he would have sold the entire longblock for complete.
TfcCDR
Sep 14, 2015 12:08 PM
Sep 8, 2015 05:21 PM
Sep 8, 2015 11:50 AM
