Need help!
Old Apr 22, 2010 | 05:58 PM
dmondeac's Avatar
dmondeac
Default Need help!
I did a PI head upgrade a few months back and now all of sudden I have an arcing that is going between the front timing cover and the crank pulley. I have looked for broken wires, bad plug wires , changed coils, etc, etc, anybody got any brilliant ideas?
Old Apr 23, 2010 | 09:37 AM
wolverine8490's Avatar
wolverine8490
Can you got into a little more detail about the arcing? Can you actually see the arc or is someone telling you that. I just am wondering how that would even be possible.
Old Apr 23, 2010 | 09:42 AM
teej281's Avatar
teej281
4.6L Section Moderator
do you have a ground attached to your motor? You need to ground your motor to the chassis.
Old Apr 24, 2010 | 07:31 AM
dmondeac's Avatar
dmondeac
Motor has two grounds but still the arcing.
Old Apr 24, 2010 | 03:48 PM
dmondeac's Avatar
dmondeac
I have changed the cam, crank sensors added an additional grounding strap but still the arcing persist and yes it is clearly visible. it is arcing about every two seconds. I have taken a grounding strap and when i touch the crank pulley the arcing stops. I have tried grounding other parts of the block, timing cover etc but the arcing only stops when I touch the crank pulley.
Old Apr 24, 2010 | 05:03 PM
0949er's Avatar
0949er
How is you ground from the block/frame to the battery?
