Comp Cams Stage 1 or 2???
Old Jun 22, 2010 | 09:23 AM
MustangManiac67's Avatar
MustangManiac67
Default Comp Cams Stage 1 or 2???
Whats the difference in the Comp Cams you find on Americanmuscle.com? Both at $590 and both are same "extremem energy" brand. only difference is one is stage 1 and one is stage 2. Anyone know the difference?
Old Jun 22, 2010 | 11:01 AM
0949er's Avatar
0949er
intake/exhaust duration are different. Stage 2 is more aggressive then stage one. With a stage 2 cam you also need to buy valve springs and retainers, where in a stage 1 you can reuse the stock valve springs.
Old Jun 22, 2010 | 04:43 PM
mrtstang's Avatar
mrtstang
PTV clearance will be very tight with the stage 2's.
Old Jun 23, 2010 | 02:18 PM
amoosenamedhank's Avatar
amoosenamedhank
Is there a reason you're focusing on comp cams over some more well liked 2v cam brands? ie Hi-Tech or Crushman
Old Jun 23, 2010 | 02:41 PM
stangalator's Avatar
stangalator
the different durations in each stage basically decides were your power band is moved. In general the the higher the stage the higher your power band will be.
Old Jun 23, 2010 | 10:53 PM
0949er's Avatar
0949er
what do you mean by more liked? There is nothign wrong with comp cam and they are excellent cams....
Old Jul 6, 2010 | 06:04 AM
MustangManiac67
So the overall consensus is Stage 1?
Old Jul 6, 2010 | 07:00 AM
PurpleIcedGT's Avatar
PurpleIcedGT
My vote is for the same exact cams as 0949er....Comp Cam Stage 2's XE 270AH
Old Jul 6, 2010 | 03:00 PM
mrtstang's Avatar
mrtstang
You really need to disregard the whole "stage" thing for a minute. The limiting factor on the stock PI heads is how much ptv clearance you have.
Bottom line...if you're staying with the stock PI heads, and don't plan on doing a blower in the near future, i'd highly recommend something like CMS stage 1's or MHS stage 2's. The Comp stage 1's should work as well, but they wouldn't be my first choice in the stock n/a application.
I did a ton of research in this area before buying my MHS stage 2's, and am glad i did.
Old Jul 6, 2010 | 03:09 PM
H0SS302's Avatar
H0SS302
+1, its a fairly well documented fact that Comp's grind isnt as good as some of its competitors. For the same money, better gains will be had.
