Upper/Lower control arms
You don't necessarily need to replace the UCA's to remove the quads, just the lowers are fine.... BUT....... The critical question here is WHICH LCA/UCA's to purchase, as many designs will be WORSE, yes.... I said worse than OEM stock in some ways!!!!!
It is very important to install ones with at least ONE spherical end on the LCA's. I recommend you leave the OEM UCA's, with only a couple exceptions. The first being if you are a DD that hits the 1/4 mile and do NOT hit the twisties hard. If you are really into the corners, leave the OEM UCA's or go for a PHB or WL and TA to address the outright garbage supposed "control" they maintain for your rear axle.
Read the Official Suspension Guide for MUCH better detail of why these items are VERY important to get right. DO NOT BUY boxed poly/poly control arms of any kind for your car, reguardless of what the manufacturer says.
Jazzer
Jazzer
Mondo.... the concern that I have is not of the particular "brand", but the design.
A spherical end is real important to help the proper articulation of the rear axle on a corner. teej has made a good recommendation in that MM ONLY sells a spherical LCA and are either heavy duty or extreme duty for those that have high HP and stickeys on the 1/4 mile.
Jazzer
Jazzer
