Valet Switch? help please
Hey guys my alarm wont stop going off and my fob on keys wont disable it so the car wont start either. I have an aftermarket prestige remote start alarm in. I think the solution is to find this valet switch to reset it but i have no idea where to look. Please help. thx
its a 2001 Mustang GT auto convertible
I couldnt remember my old password for my other account so i had to start this new user name. But i used to be on this site a bunch and i know yall know what your talking about.
Well I found this, which goes along with the valet button theory...check the glove box, center console, under seat, etc for that damned button..
The alarm seems to be in long tamper mode.
You will need to reset, and possibly
re program the remotes. That part you will need
your manual for, but the aftermarket alarm
seems to be doing it's job.
At least we know it's installed correctly
which is actually a good thing here.
Ok, try this.
Put the key in the ignition, and turn forward
all the way just before cranking. Then within
5 seconds, locate, press and hold in the
valet/overide button, found under the
dash area, (push button, spring loaded)
until the installed LED (the blinking light)
in your dash area goes on solid,
and the siren chirps once.
(Your valet switch might be the toggle
(on/off) type. in this case, key on,
flip switch in opposite direction,
then turn the key off.)
This should reset the alarm, and reset
the grounded relay on the starter wire,
allowing you to start the engine.
At this point, the only thing working would
be the keyless entry from the alarm,
if it came equipped that way.
Just Repeat these steps to place it
back to usable armed mode.
You may get 2 chirps, confirming it,
and the lights may flash twice as well.
Ok, try this.
is it going off at random or just constantly going off...because when my alarm was going off at random it was PATS interfering with the aftermarket setup and they had to put resistors in and **** to get them to work together rather than against each other
